Blkzx3
#1 Posted : Sunday, November 3, 2013 7:10:44 AM(UTC)
Blkzx3
Hi all! Hoping for some help - this has been a long, frustrating battle! Last week we started smelling an electrical burning smell from the washer. Soon after that it stopped mid cycle and would not restart in any cycle. I assumed the motor had over heated and unplugged the washer and waited till morning where I plugged it back in and got it to spin all the water out. I assumed it was a bad motor and ordered a replacement. I also ordered a new clutch and coupling and agitator dogs. Figured I'd give it an overhaul of sorts while I had it apart. I also cleaned the drum and basket to get rid of the grossness in there. Everything finally back together I started a test load (empty) on quick wash. All seemed ok so I ran a full load. During the spin cycle I now hear a load constant noise (and only during that cycle) that sounds like maybe a loud buzzing. This wasn't there before . Did I put something back together wrong? Is my new clutch bad maybe or should I assume the worst and figure I have a bad transmission?
I'm hoping it's something easy! There was a lot of foul language thrown at my washer yesterday as I did all this - hope it's not mad at me!
Thanks all in advance!
Tony
fairbank56
#2 Posted : Sunday, November 3, 2013 7:24:35 AM(UTC)
fairbank56
Groups: Expert
Is the gearcase fully seated up against the mounting studs? If so, post a video to youtube so we can hear the noise.
Eric
Blkzx3
#3 Posted : Sunday, November 3, 2013 2:13:53 PM(UTC)
Blkzx3
Here is a link to the noise - Washer noise - YouTube if it works that is. I've never loaded anything before to YouTube. I will be taking it apart again soon!
fairbank56
#4 Posted : Sunday, November 3, 2013 2:55:21 PM(UTC)
fairbank56
Groups: Expert
Might be something in the pump. Pull the pump away from the motor shaft and try spin again.
When you put the new coupler on, did you make sure to put the two plastic halves on far enough so that they are flush with the end of the motor and gearcase shafts?
Blkzx3
#5 Posted : Sunday, November 3, 2013 3:04:46 PM(UTC)
Blkzx3
Thanks - I actually did look at that. Nothing in the pump except for water. Spun it a bit and all seemed ok. I had pulled the cover off and saw one of the clips had come off the pump and put that back on and tried it without a load - just spin and it sounded good. When I ran a load the noise was there. It happenes on rinse and spin - I originally thought it was just spin.
Blkzx3
#6 Posted : Wednesday, November 6, 2013 5:39:22 AM(UTC)
Blkzx3
Hi all - thanks for the help. I broke down the washer again and reseated the clutch and everything. After it was back together all was quiet again. Must have been some adjustment somewhere - but it works now the right way! Thanks again for the help!
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
Whirlpool Washer Noise (Washer Repair)
by cheriemarie78 9/5/2017 8:04:41 AM(UTC)
Whirlpool washer noise during braking (Washer Repair)
by Mommeeu 8/6/2016 9:50:02 AM(UTC)
WHIRLPOOL WASHER noise knocking at end of spin cycle (Washer Repair)
by weav1 10/13/2012 11:31:57 AM(UTC)
Whirlpool Washer Noise when Spinning (Washer Repair)
by MayoVetman 3/22/2012 12:09:38 PM(UTC)
Whirlpool Washer noise on high spin (Washer Repair)
by dmmetzger 2/21/2011 4:32:42 PM(UTC)
Estate Whirlpool washer noise during spin (Washer Repair)
by tom gottler 12/20/2008 7:39:44 AM(UTC)
