Nikkilee
#1 Posted : Monday, October 14, 2013 6:37:44 PM(UTC)
Nikkilee
My washer never drained, I drained it manually and the only thing it does on any setting is hum, I have already checked the lid switch and that is not the problem, not sure what to start checking or how to check it.
Thanks,
Nikki
fairbank56
#2 Posted : Monday, October 14, 2013 7:13:41 PM(UTC)
fairbank56
Groups: Expert
Remove the cabinet, bypass lid switch and pull pump from motor to see if it will run without pump. (pump may be jammed). If it still won't run, pull motor and see if it will run just sitting on the floor. Place your foot on the motor as it will jump if it starts. Rotate gearcase input shaft by hand. CW for spin, CCW for agitation.
Eric
Nikkilee
#3 Posted : Tuesday, October 15, 2013 4:07:23 PM(UTC)
Nikkilee
Thanks, I watched a youtube video to figure out how to take apart the washer and I pulled the pump off and I don't know how it got in there but the 7 year olds sock was jammed in the pump.. managed to get it out and put washer back together and works great.
Roper Top Load Washer RAS7133PQ0 Problem (Washer Repair)
by nkaufman1 4/7/2023 9:02:20 AM(UTC)
Roper Top load Washer No Cold Water (Washer Repair)
by James0188 5/4/2017 1:30:06 PM(UTC)
Roper top load washer shakes violently...HELP. (Washer Repair)
by Hexster 8/27/2011 5:12:56 PM(UTC)
Roper Top Load Washer fills slowly (Washer Repair)
by dougdawn707 3/8/2010 6:16:58 PM(UTC)
Roper Top Load Washer Stops Mid Cycle (Washer Repair)
by wisfamily 10/28/2008 6:51:59 PM(UTC)
