jwb188
#1 Posted : Saturday, September 21, 2013 10:36:21 AM(UTC)
jwb188
I just replaced the timer. The dryer comes on but the timer does not change positions.
HumboldtRepairMan
#2 Posted : Saturday, September 21, 2013 1:32:36 PM(UTC)
HumboldtRepairMan
Check your voltage going to the machine has to be 240v and good connections and a good harness on a dedicated circuit just for the dryer and not with anything else.
#3 Posted : Monday, September 23, 2013 2:44:31 AM(UTC)
Does the timer not advance in both timed dry and auto modes?
jwb188
#4 Posted : Wednesday, September 25, 2013 7:59:32 PM(UTC)
jwb188
Voltage is good. Connections are fine. The company sent me a replacement timer, but it acts the same as the last one.
Timer does not advance in any mode. It stays where ever it is when I turn it on. If I set it for dry or timer the dryer gets hot. If I set it in the middle of cool down, it acts appropriately.
#5 Posted : Thursday, September 26, 2013 4:05:11 AM(UTC)
Parts for Maytag MDE7400AYW Dryer - AppliancePartsPros.com
Odds are that the dryness board (item 13 in section 02) is bad.
It is what drives the timer motor.
Note that if you click on the part's picture/description a new page will oepn with more info about it.
New Timer doesn't time (Dryer Repair)
by jgil 6/13/2017 7:54:53 PM(UTC)
New Timer does not seem to advance (Refrigerator & Freezer Repair)
by VA_DIY 7/31/2015 10:06:14 AM(UTC)
Maytag Atlantis new timer not working (Dryer Repair)
by blewis123456 11/5/2014 8:26:45 AM(UTC)
New Timer Part Doesn't Work (Dryer Repair)
by tchart 8/10/2013 9:41:09 AM(UTC)
New timer will not advance (Washer Repair)
by meganbella 4/5/2013 7:02:18 AM(UTC)
Whirlpool dryer will not shut off after new timer replacement (Dryer Repair)
by grayfeathers 10/23/2012 4:23:08 PM(UTC)
New timer, lid switch bypassed. Need help with diagnosis (Washer Repair)
by tejuguasu 9/11/2012 6:13:52 PM(UTC)
WP Ultimate Care 2 washer problems...new timer didn't fix (Washer Repair)
by HunterTinsley 4/6/2012 6:11:49 PM(UTC)
new timer, many tests, still won't work (Dryer Repair)
by zenart 1/22/2012 7:05:24 AM(UTC)
black wire on new timer (Refrigerator & Freezer Repair)
by tjescalona 12/4/2011 7:16:04 AM(UTC)
Kinmore New Timer Old knob (Washer Repair)
by 1015eclipse 8/9/2011 7:11:33 PM(UTC)
put in new timer and still not going through cycles (Washer Repair)
by Indianriver 6/26/2011 3:58:40 PM(UTC)
New timer, still stcuk (Dryer Repair)
by mkitchin 12/31/2010 12:26:10 PM(UTC)
GE Dryer - new timer still does not count down (Dryer Repair)
by jmb322 12/29/2010 4:55:57 PM(UTC)
new pump and new timer (Washer Repair)
by mikey995102002@yahoo.com 3/29/2010 11:14:25 AM(UTC)
