Revelation320
#1 Posted : Wednesday, September 4, 2013 4:41:04 PM(UTC)
Revelation320
Washer Model number LSR8444Q0
Washer Serial number CM4823083
The Lid Switch Assembly (AP3100003) went out. The part was ordered and reinstalled. Now, however, whenever the cycle gets to rinse the laundry machine just buzzes. So now the dial must be manually set to the spin cycle in order to finish doing the laundry (without a rinse).
Is the problem the Motor? The motor coupling? The timer? Or something else entirely?
sidfink43
#2 Posted : Wednesday, September 4, 2013 5:28:42 PM(UTC)
sidfink43
If the machine will go through the complete wash cycle, including fill, agitate, drain and spin then that suggests there is nothing wrong mechanically with the machine and that the problem is the timer.
Try replacing it, and if you buy from this site and the part does not fix the problem you can return it.
Good luck.
Revelation320
#3 Posted : Thursday, September 5, 2013 5:08:33 AM(UTC)
Revelation320
Why do you think the timer went out at the same time the switch broke?
sidfink43
#4 Posted : Friday, September 6, 2013 6:05:55 AM(UTC)
sidfink43
I don't know, the two are unrelated. It could be just coincidence, or it may not be the timer at all and there may be something in the wiring.
Let's see what happens when you replace the timer.
GE washer Problems w/ Agitation GCWN3000M1WS (Washer Repair)
by ps33 12/19/2020 4:19:13 PM(UTC)
Kenmore VMW 22352 Washer Problems (Washer Repair)
by Papa_omero 3/11/2019 5:25:53 PM(UTC)
Whirlpool Duet Sport Washer problems (Washer Repair)
by bdmbluegrass 1/11/2017 11:54:22 AM(UTC)
washer problems (Washer Repair)
by porterbridges 1/18/2015 10:53:23 AM(UTC)
Commerical Washer Problems (Washer Repair)
by sherryash 12/18/2012 3:11:25 PM(UTC)
by mariela 10/24/2012 7:44:31 PM(UTC)
Bosch Dishwasher problems (Dishwasher Repair)
by Manuel Arce 9/15/2012 9:14:41 AM(UTC)
Whirlpool dishwasher Problems (Dishwasher Repair)
by captbud 8/1/2012 10:21:44 AM(UTC)
by malon66 6/21/2012 6:17:18 PM(UTC)
WP Ultimate Care 2 washer problems...new timer didn't fix (Washer Repair)
by HunterTinsley 4/6/2012 6:11:49 PM(UTC)
Whirlpool Washer Problems (Washer Repair)
by GK12 3/4/2012 1:28:37 PM(UTC)
LG Dishwasher problems HELP! (Dishwasher Repair)
by djmcheme 11/19/2011 11:05:29 AM(UTC)
Intermittent washer problems (Washer Repair)
by rscha787 10/12/2011 5:56:35 PM(UTC)
by jamesnl 10/9/2011 2:13:43 PM(UTC)
maytag washer problems (Washer Repair)
by djv106 9/24/2011 7:40:00 AM(UTC)
