anniepesathor
#1 Posted : Tuesday, September 3, 2013 6:31:00 AM(UTC)
anniepesathor
I need to check to see if I need a new timer. The problem is I can't remove the start button to get to the screws that are behind it. Before I was able to pull on the start button because it seemed to be sticking. Dirty maybe? So when I close the dryer door and have it set on dry, the dryer automatically starts. Had to disable buzzer, wouldn't stop.
#2 Posted : Wednesday, September 4, 2013 3:44:47 AM(UTC)
I think on this unit the timer knob has a cap in the center that should pry off.
Then under the cap is a nut that must be remover to remove the knob from the timer.
Perhaps the following parts breakdown from Maytag may be helpful to you.
http://www.maytag.com/digitalas...t%20List%20-%20DE382.pdf
anniepesathor
#3 Posted : Wednesday, September 4, 2013 9:47:47 AM(UTC)
anniepesathor
Thank you for helping me out! I took apart start button, cleaned all around, same thing happened. When I turn the knob on dry and close the door it automatically starts the dryer, I don't even push the start! Guess I need a new timer!
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Maytag electric dryer question (Dryer Repair)
by cramerj 2/15/2021 4:59:49 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Maytag electric dryer takes too long. Troubleshooting guide? Service manual? (Dryer Repair)
by MargretS 11/2/2014 12:08:03 PM(UTC)
Maytag Electric Dryer Light Works But Won't Turn On (Dryer Repair)
by MaytagManNC8 4/11/2014 3:21:09 PM(UTC)
Maytag electric dryer new Thermistor going bad (Dryer Repair)
by derektuan 3/25/2014 5:59:38 PM(UTC)
Maytag electric dryer won't heat (Dryer Repair)
by kspeters 2/6/2013 5:23:47 PM(UTC)
Maytag Electric dryer (Dryer Repair)
by shulskyt 2/6/2013 1:57:13 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
maytag electric dryer runs for 10 min and shuts off (Dryer Repair)
by bearsforme_22 3/8/2012 2:02:11 AM(UTC)
Maytag Electric Dryer Won't Start (Dryer Repair)
by Rosebud42 1/6/2012 2:50:38 PM(UTC)
