I followed the instructions that came with the LP conversion kit to the letter. Top burners work fine. The ignitor for the oven glows but the burner never lights. I believe all air is out of the lines as it took a few moments for each burner to light but they finally did. I don't hear any gas/air release coming from the oven burner nor do I smell any LP. HELP?
Flipped The regulator Cap To The Lp Position (Solid In, Hollow Out) And Reinstalled Per Instructions. Then Turned The Oven Burner Spud Down To The Lp Position As Instructed. Igniter Flows But No Evidence Of Gas Coming Out Of Burner When Turned On.
Check to make sure you have 120v going to the ignitor from the main board when pressing bake. Could be the ignitor is going bad, check it with an amp clamp it needs to pull at least 3 amps to release the safety valve. It may also have a safety valve issue perhaps.......
Originally Posted by: HumboldtRepairMan  Check to make sure you have 120v going to the ignitor from the main board when pressing bake. Could be the ignitor is going bad, check it with an amp clamp it needs to pull at least 3 amps to release the safety valve. It may also have a safety valve issue perhaps....... Will check that. Thanks a gob! This gives me some direction.:eek:
Originally Posted by: beebem97  Will check that. Thanks a gob! This gives me some direction.:eek: Checked igniter, I am getting 120v at the plug and there are no fault codes on the display panel yet the oven burner still doesn't light.
120v at the ignitor when you put it in bake mode..........not the wall plug.
Originally Posted by: HumboldtRepairMan  120v at the ignitor when you put it in bake mode..........not the wall plug. Yes sir. Had it in bake mode.
If you have 120v at the bake ignitor and its not glowing or pulling 3amps you have a bad ignitor.
Still cannot get the door on, the holes do not line up with anything. One manual we found said to put the packing pins in the hinge when removing the door. Number one:we do not have any pins; number two the door is off now. I wonder if this an old, old oven although I have checked and rechecked the model number and it is correct. Help! Thank you:confused:
