gsneesby@juno.com
#1 Posted : Sunday, August 18, 2013 1:40:54 PM(UTC)
gsneesby@juno.com
We have an Amana ARB2517csl bottom mount freezer refer. this morning it was making a cliciking sound trying to start the compressor. I tested the compressor with a VOM, no shorts to ground. We emptied the unit and it sat tfor 5-6 hours. I turned power back on and the compressor started normally- no clicking sounds. My question is 1. is the defrost timer electrically powered or did it complete its cycle without power and allow the start relay to function normally and 2. where is the timer located on this unit?
Thanks for any suggestions.
#2 Posted : Monday, August 19, 2013 1:25:08 AM(UTC)
You have a hard starting compressor that fails to start during low, line voltage periods.
gsneesby@juno.com
#3 Posted : Monday, August 19, 2013 5:45:31 AM(UTC)
gsneesby@juno.com
Good possibility, I live in a rural area, at the end of the power line and lots of irrigation wells upstream from me.
Thanks for the suggestion.
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
