rlmkjones
#1 Posted : Saturday, August 3, 2013 5:39:43 PM(UTC)
rlmkjones
Hi
I have an old kenmore freezer model #106.8241541 that quit working. I noticed a smell of burnt wiring. When I checked the relay and over load it had gotten real hot. The compressor checks out ok with the ohm meter. The part#s for the relay and overload are not available anymore. Is there any kind of kit that would work to get it going again? It has r12 refrig and has only two wires to it,red and white.
Thanks for any help
Rick
#2 Posted : Tuesday, August 6, 2013 1:41:06 AM(UTC)
Ohm checks on compressor windings will not detect bad windings. Check for continuity to ground on any compressor pin.
rlmkjones
#3 Posted : Tuesday, August 6, 2013 6:46:15 AM(UTC)
rlmkjones
Thanks for the reply. Should the ohms reading be infinite or is there a range that would be ok?
Thanks again
#4 Posted : Tuesday, August 6, 2013 7:10:04 AM(UTC)
There should be no resistance to ground. If ok, you can order a start device URO41. The common compressor pin is usually the top pin, start pin, bottom left, run pin, bottom right. I assume the original start device was a coil type, is that true?
rlmkjones
#5 Posted : Tuesday, August 6, 2013 10:16:06 AM(UTC)
rlmkjones
That is correct, it had a small round black thing that had a red wire from it to the coil. The round thing was burnt and crumbled when i took it out.
Kenmore Freezerless refrigerator (Refrigerator & Freezer Repair)
by bajohnsons 8/14/2020 8:39:50 AM(UTC)
Beeping from Kenmore Freezer!! (Refrigerator & Freezer Repair)
by agdodge4x4 6/30/2019 8:57:55 AM(UTC)
2 year old Kenmore freezer died...? (Refrigerator & Freezer Repair)
by Roy404 8/6/2015 12:38:43 PM(UTC)
25326442100 Kenmore Freezer Problems (Refrigerator & Freezer Repair)
by cover 5/21/2015 6:47:34 PM(UTC)
Kenmore Freezer 106.53554202 leaking (Refrigerator & Freezer Repair)
by nikecar 9/8/2014 8:10:24 AM(UTC)
Kenmore freezer cold, fridge not cold (Refrigerator & Freezer Repair)
by bc. canuck 7/8/2014 9:06:32 AM(UTC)
Kenmore freezer fan cycling on and off every 2 seconds (Refrigerator & Freezer Repair)
by kalamajo 4/29/2014 8:02:22 PM(UTC)
Kenmore freezer fan keeps running (Refrigerator & Freezer Repair)
by John558 12/2/2013 9:15:25 PM(UTC)
Kenmore freezer and refrigerator not cooling enough (Refrigerator & Freezer Repair)
by vikasintl 8/27/2013 12:54:20 PM(UTC)
Kenmore Freezer Help (Refrigerator & Freezer Repair)
by Keith5523 7/8/2013 3:29:18 AM(UTC)
Kenmore freezer on bottomm fridge freezing up and fridge not cooling (Refrigerator & Freezer Repair)
by homescool05@bellsouth.net 7/4/2013 3:05:12 PM(UTC)
Kenmore freezer stopped working (Refrigerator & Freezer Repair)
by Renael 5/18/2013 10:10:56 PM(UTC)
Water drips from my Kenmore freezer into fridge (Washer Repair)
by rmdaddy1 4/19/2013 10:23:04 AM(UTC)
kenmore freezer won't stop running (Refrigerator & Freezer Repair)
by d_rogers@charter.net 1/29/2013 2:03:43 PM(UTC)
Kenmore freezer not cooling (Refrigerator & Freezer Repair)
by aiea 12/7/2012 8:35:56 AM(UTC)
