2 Pages<12
dorlando
#11 Posted : Friday, July 19, 2013 3:46:39 PM(UTC)
dorlando
I took another look and the tub does start to move a bit before the dogs
meet but the dogs definitely are meeting, then when I release the pulley they separate. At this point I'm not sure if I can do the rest you are talking about. I have to decide if I am going to have someone look at it.
Do you think the transmission is fine but maybe it is just a bearing? There is a local repair shop that charges $45 for diagnosis and then parts plus a little more labor if needed. I don't mind taking it in if it may be something minor, but not for the transmission. Your thoughts? Thanks for your help.
fairbank56
#12 Posted : Friday, July 19, 2013 4:00:26 PM(UTC)
fairbank56
Groups: Expert
I can't really say about the transmission. If it's the lower bearing binding up, that is part of the transmission and is not a normal replacement item. You would have to replace the transmission if that bearing is faulty. As I said, If I was working on it, I would rule out any problem with the motor not being up to the task and go from there. The $45 diagnosis charge is not bad so see what they say and then decide. Let us know what you find out. I will say, that if the washer is in good shape otherwise, not rusting out or anything, it may be worth it to fix. I have a similar GE model that is older than yours. Last year, I had to replace the motor and transmission. Of course, it was parts at a discount only but I refuse to buy the junk washers they are selling nowadays. The only decent new toploader that I would recommend is one of the Speed Queen models and they run around $800.
Eric
dorlando
#13 Posted : Saturday, July 20, 2013 5:08:12 AM(UTC)
dorlando
is there any chance it can be the lid switch? I just want to rule that out for sure. When I manually press it the tub moves just an inch and you hear the clunk, that is it.
fairbank56
#14 Posted : Saturday, July 20, 2013 5:54:07 AM(UTC)
fairbank56
Groups: Expert
Not likely. The motor runs so the switch is closing. If the contacts are in very bad shape though, it could cause a voltage drop at the motor. Another reason for checking voltages at the motor. You could make a suitable jumper to jump it out to rule it out as a problem.
Eric
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
GE Washer not Spinning (Washer Repair)
by jkomes 12/19/2013 6:52:43 PM(UTC)
GE washer not spinning out all the water (Washer Repair)
by sbryant73 11/16/2013 2:51:08 PM(UTC)
by Tigerhawk247 11/5/2013 7:14:29 PM(UTC)
by jschust 10/6/2013 9:17:23 AM(UTC)
by jlbyrnes3 4/8/2013 10:54:18 PM(UTC)
by JD0034 1/1/2013 5:13:24 PM(UTC)
GE washer not spinning (Washer Repair)
by mau397 5/6/2012 2:38:20 PM(UTC)
GE Washer not spinning and smells strange (Washer Repair)
by greenfelt22 7/26/2011 6:26:28 AM(UTC)
GE Washer not spinning. Bad motor or transmission? (Washer Repair)
by MrJosh 6/17/2009 7:02:48 AM(UTC)
2 Pages<12
