2 Pages12>
MamaFixedIt
#1 Posted : Friday, July 19, 2013 7:47:18 AM(UTC)
MamaFixedIt
Kind of out of the blue my washer stopped spinning and agitating. I'm not sure what the problem is.
About a year ago I replaced the lid switch. About 6 months ago I had to reset the motor. Other than that it's worked just fine.
I took the front panel off and everything looks ok. The motor looks fine and the belt is in good shape.
When I turn on the washer it fills and goes through all of the cycles just like normal. It just doesn't spin or agitate. I'm at my wits end.
Can anybody help?
fairbank56
#2 Posted : Friday, July 19, 2013 8:22:14 AM(UTC)
fairbank56
Groups: Expert
You have been a member since:: 10/16/2012(UTC)
There is no reset for the motor on this washer. Does the motor make any noise at all while in agitate or spin? If totally quiet, check the lid switch. If the lid switch is bad, the motor won't work. To check lid switch, open control panel and unplug the 10 pin plug from the control board and check continuity between the orange and yellow/red wires. Should be 0 ohms with lid closed. If lid switch checks out ok, retrieve the tech sheet from inside control panel. It will tell you how to get into service mode to check for control board error codes.
Eric
MamaFixedIt
#3 Posted : Friday, July 19, 2013 9:40:39 AM(UTC)
MamaFixedIt
I used this method to reset the motor.
The lid switch is brand new. I'll check it again though.
There is no noise during the spin or agitate cycle.
Where do I find the control panel and how do I check the continuity?
fairbank56
#4 Posted : Friday, July 19, 2013 10:01:16 AM(UTC)
fairbank56
Groups: Expert
That reset procedure is for a hydrowave washer, yours is not one of those. I think you should probably call a tech if you don't know how to use a multimeter.
Eric
MamaFixedIt
#5 Posted : Saturday, July 20, 2013 8:34:49 AM(UTC)
MamaFixedIt
Ok, so the lid switch is fine.
I was able to locate the control panel and get it into test mode. To tell the truth i'm not entirely sure if I was getting an error code or not. The directions and chart were nearly impossible to read.
I'm wondering if there is a clearer version on line.
What other things should I test? Like KerriH I too want to fix this myself.
fairbank56
#6 Posted : Saturday, July 20, 2013 9:11:21 AM(UTC)
fairbank56
Groups: Expert
After you enter service mode, all status indicators should be lit. Now rotate the cycle knob two clicks to the right. If all indicators go out, there are no errors. If any of them are on, which ones are they?
Eric
MamaFixedIt
#7 Posted : Saturday, July 20, 2013 10:52:12 AM(UTC)
MamaFixedIt
12 min and rinse are on. Counting from left to right that's #4 & #7.
fairbank56
#8 Posted : Saturday, July 20, 2013 11:11:32 AM(UTC)
fairbank56
Groups: Expert
That's a no fill error and thermistor error. If the washer takes a long time to fill it will give the no fill error. The thermistor is a temperature sensor on the water inlet valve that is used by the control board to cycle the hot/cold valves on/off for proper overall temperature of the water in the tub. These errors should not stop the washer from working. Clear the errors by pressing the start button while in service mode error code check. Then unplug the washer for 2 minutes and plug back in to reset the control board.
Eric
MamaFixedIt
#9 Posted : Saturday, July 20, 2013 1:39:00 PM(UTC)
MamaFixedIt
Ok, I reset the board. Now what?
fairbank56
#10 Posted : Sunday, July 21, 2013 3:53:53 AM(UTC)
fairbank56
Groups: Expert
Do you know how to use your multimeter to make continuity checks and live line voltage checks? If not, call a tech or parts swap til you get it fixed. If the lid switch is good, the motor makes no noise when in agitate or spin, you could have a bad control board, motor, or wiring issue. You either troubleshoot with meter and wiring diagram or parts swap.
Eric
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
won't spin or agitate (Washer Repair)
by KeithMinnick 4/2/2018 1:35:46 PM(UTC)
Kenmore model 110 Won't spin or agitate (Washer Repair)
by gibstuff 6/6/2017 10:27:57 PM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE Profile 175D2750G151 Won't spin or agitate (Washer Repair)
by Mitchina 6/28/2015 6:04:43 AM(UTC)
Washer Won't Spin or Agitate, but Drains Properly (Washer Repair)
by Levistahl 10/16/2014 10:21:32 AM(UTC)
washer won't spin or agitate (Washer Repair)
by tibbs1212 9/7/2014 6:01:49 PM(UTC)
GE Hydrowave washer won't spin or agitate (Washer Repair)
by lilajfischer 8/7/2014 3:20:38 PM(UTC)
Hotpoint washer won't spin or agitate (Washer Repair)
by cmccms 1/28/2014 10:42:17 AM(UTC)
Kenmore washer won't spin or agitate (Washer Repair)
by jwes 1/23/2014 6:22:22 PM(UTC)
Whirlpool Washer won't Spin or Agitate (Washer Repair)
by Jimmimech 1/12/2014 6:57:46 PM(UTC)
by mmcgarcia 6/15/2013 12:47:09 PM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
2 Pages12>
