12 Pages«<89101112>
RenovatorGuy
#91 Posted : Friday, June 1, 2012 1:52:02 PM(UTC)
RenovatorGuy
Originally Posted by: rsperson Go to Quoted Post
Like the subject said - broke into 5 pieces :mad::eek: Used butter knife - panel bends, cracks and breaks
Yes mine too no matter how careful I was and I'm not a DIY newbie with fixing things. Trim piece on order now :rolleyes:
Vid I posted in above post is exactly what pertains to my model (KHMS155LSS4) after trim piece #2 is removed showing no handle screws. One thing the vid doesn't show that was the only way I got mine apart, was to bend the metal away at each plastic hook for much easier removal like in vid. Don't forget to bend the metal back to original shape once done with installing new handle and sandwiching the two door components back together. That will allow trim piece to snap back in place correctly.
Why oh why didn't they give us a 'real' stainless steel handle in the first place. Certainly paid a pretty penny for the stainless steel model...what cheap-o's.
richmart
#92 Posted : Sunday, January 27, 2013 5:58:39 PM(UTC)
richmart
I have a Whirlpool Model MH1150XMS3 and broke the inner plastic bit that I was removing with the butter knife. Do I have to replace the entire door to fix my mistake? I really hope not and am regretting not using a professional instead of thinking that I can do this for myself.
By the way, when I finally got it off I couldn't find the screws that I needed to replace the broken door handle.
#93 Posted : Monday, January 28, 2013 7:20:49 PM(UTC)
Hello,
Did you mean the inner frame (#2 at the diagram)? If this is correct then you can replace it.
- The inner frame Part number: 8169545
P.S. Go back to page 8 and check out the reply posted by TONY7666.
BuffaloBill
#94 Posted : Tuesday, June 4, 2013 6:37:56 AM(UTC)
BuffaloBill
No pictures displayed here. What happened to the images?
Julia222
#95 Posted : Monday, June 17, 2013 7:36:48 AM(UTC)
Julia222
Thank you so much for the help, after watching the video you showed and taking my time to do as you showed and not getting frustrated, the microwave frame came out in a cinch, I removed the lower screw and am ordering the new handle today. It is very easy to replace. It should take about 5 minutes once new handle arrives, if that long. Thank you, y'all are great.
Julia
Julia222
#96 Posted : Wednesday, June 19, 2013 9:05:15 AM(UTC)
Julia222
Mickey
I'm waiting for handle to arrive and then I could do video of installing it, but not sure how to upload video. Getting to the bottom screw looks harder than it is, I have already removed old piece of handle from the bottom and it will really only take a couple of minutes to install new handle. When I started looking into this, there were comments that the whole door would have to be replace, or may just have to buy new microwave. I'm so happy it was so easy, the hardest part is waiting for the new handle and limiting the use of the microwave with the "top screw only" holding the handle on, have to be gentle opening door.
Julia222
Whartonloser
#97 Posted : Saturday, June 29, 2013 12:14:55 PM(UTC)
Whartonloser
I just replaced my door handle on my microwave, watched the attached video update above and swapped out the broken one in about 3 minutes....WATCH THE VIDEO...IT WILL MAKE SENSE !! Could not be easier....thanks AP Pros!
Julia222
#98 Posted : Monday, July 1, 2013 10:10:58 AM(UTC)
Julia222
I did a video showing me replacing my handle. Microwave is almond color I think you can see what I&#8217;m doing better than the black microwave video. http://youtu.be/NJm3GOMUszg
Julia:)
Mstone8675@optonline.net
#99 Posted : Thursday, October 10, 2013 7:05:11 AM(UTC)
Originally Posted by: Admin / APP Team Go to Quoted Post
Here is a short clip that shows how to remove the inner door panel on most microwaves. Hope it helps.
[youtube]nIdT4kS3noY&rel=1[/youtube]
:) This Youtube really helped. Thank you
#100 Posted : Thursday, October 10, 2013 7:06:26 AM(UTC)
Originally Posted by: Julia222 Go to Quoted Post
I did a video showing me replacing my handle. Microwave is almond color I think you can see what I’m doing better than the black microwave video. http://youtu.be/NJm3GOMUszg
Julia:)
Excellent Thank you:)
Guest (10)
GE Profile #PVM917DFBB microwave handle removal (Microwave Repair)
by trifive 10/26/2019 10:36:24 AM(UTC)
microwave handle repair (Microwave Repair)
by rthill01 1/28/2013 3:06:37 PM(UTC)
Replacing microwave handle (Microwave Repair)
by gregx5 5/25/2011 11:39:20 AM(UTC)
Microwave handle (Microwave Repair)
by mrorvis 2/23/2011 3:23:42 PM(UTC)
Microwave handle repair (Microwave Repair)
by rburton61 11/26/2010 9:59:01 AM(UTC)
microwave handle broke off (Microwave Repair)
by bigbro 12/9/2009 6:41:06 AM(UTC)
Installing Microwave handle (Microwave Repair)
by Buckey1 5/12/2009 4:17:22 PM(UTC)
by gdevas 4/29/2009 2:40:29 PM(UTC)
Microwave Handle (Microwave Repair)
by tyohe@yoheconsulting.com 4/1/2009 9:49:31 AM(UTC)
Kenmore microwave handle repair (Microwave Repair)
by ginasal 3/20/2009 7:23:07 PM(UTC)
Broken off GE Microwave Handle pn #AP3187809 (Microwave Repair)
Belarus mrbotto 2/7/2009 2:37:37 PM(UTC)
Microwave Handle replacement (Microwave Repair)
Belarus Yusuf 2/6/2009 1:55:27 PM(UTC)
Install GE Microwave handle (Microwave Repair)
by icandoitmyself454 2/5/2009 4:43:55 PM(UTC)
How to install new microwave handle (Microwave Repair)
by Chalcook 12/23/2008 3:33:31 PM(UTC)
GE Microwave Handle Replacement (Microwave Repair)
by Graham Brown 12/14/2008 9:32:23 AM(UTC)
12 Pages«<89101112>
