I have a broken handle on my microwave. The top of the handle came off easily as it is attached with a visible screw. The bottom of the handle broke off and there is no visible means of getting it off. I have tried to simply unscrew is from the broken off side, but it will not come off. I appreciate any suggestions.:confused:
:confused: Originally Posted by: Buckey1  I have a broken handle on my microwave. The top of the handle came off easily as it is attached with a visible screw. The bottom of the handle broke off and there is no visible means of getting it off. I have tried to simply unscrew is from the broken off side, but it will not come off. I appreciate any suggestions.:confused:
