abinosa
#1 Posted : Wednesday, June 19, 2013 10:34:26 AM(UTC)
abinosa
Hello,
Maybe someone can help me. My wall oven suddenly turn off and starting beepping. Sometimes I will see E6 F2 on the screen, then I would press clock and it will show the time as normal. I was able to use the oven one time as it stayed on long enough, but most of the time it is off and I do not see nothing on the screen where the time will normal show. But I am able to press the buttons and it will beep. But I cannot operate the oven when the screen is off.
Thanks for you help.
Andrew
#2 Posted : Thursday, June 20, 2013 1:29:06 AM(UTC)
Parts for Whirlpool RBD305PDS14 Wall Oven - AppliancePartsPros.com
Your error is a communication error between the keypad (control panel) and the control board/timer.
Try removing power from the unit for a couple minutes to see if it will reset.
Check all connections at the control board.
Try cleaning the ribbon cable on the keypad and the connector on the control board.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If neither of the above does nothing then I would replace the control board.
This is a bit of a guess as there is no way to check which part is bad.
File Attachment(s):
RBD305.pdf (505kb) downloaded 6 time(s).
abinosa
#3 Posted : Friday, June 21, 2013 6:39:31 AM(UTC)
abinosa
It looks like the control board is bad. I am ordering it and replacing. Thanks for your help denman.:cool:
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 6/4/2023 8:04:00 PM(UTC)
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 5/23/2022 12:46:49 PM(UTC)
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 1/19/2018 1:24:46 PM(UTC)
Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 1/9/2015 6:04:08 AM(UTC)
by dragonflies64 9/23/2014 7:07:41 PM(UTC)
Whirlpool double wall oven (electric) upper oven not working (Oven Repair (including Ranges and Cooktops))
by JayTeeC 3/11/2014 4:54:07 PM(UTC)
Whirlpool Double Wall Oven Fan (Oven Repair (including Ranges and Cooktops))
by bernardv 3/10/2012 9:57:23 AM(UTC)
Whirlpool Double Wall Oven (Oven Repair (including Ranges and Cooktops))
by myoven 11/22/2011 6:38:55 AM(UTC)
Removing trim and control panel from Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by Lifterfe 4/23/2011 4:10:10 PM(UTC)
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 10/31/2010 7:20:02 PM(UTC)
Whirlpool Double Wall Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by DaveinMD 12/1/2009 6:28:08 AM(UTC)
by jledereich 9/22/2009 9:51:35 AM(UTC)
Whirlpool Double Wall Oven D.O.A (Oven Repair (including Ranges and Cooktops))
by JaredB 12/8/2008 6:24:40 PM(UTC)
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd (Oven Repair (including Ranges and Cooktops))
by sillyshopper 2/9/2008 8:02:27 AM(UTC)
Whirlpool Double Wall Oven - Top Oven Not Working (Oven Repair (including Ranges and Cooktops))
by bigguy 11/15/2007 7:18:45 AM(UTC)
