Collums4
#1 Posted : Friday, June 14, 2013 5:42:06 AM(UTC)
Collums4
Dryer was working fine. Dried one load of clothes. Removed and placed second load in( dryer was cool, I'm one of those that let's them sit hoping they will fold themselves). Set my cycle then pushed the start button and nothing. Husband checked breaker, fine. Unplugged let it set for a few plugged back in and tried once more still nothing. What should we do next? Thanks!
#2 Posted : Friday, June 14, 2013 6:00:51 AM(UTC)
Parts for Whirlpool WED5500SQ0 Dryer - AppliancePartsPros.com
See the attachment for your wiring diagram
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the unit has a drum light, does it work.
If it does light then you know that you have power to drive the motor.
Does the door switch turn the light off?
A likely culprit is the thermal fuse (item 7 in the Bulkhead Parts section). Check it wih a meter. Be sure to unplug the unit when doing this.
If it is blown be sure to check/clean your vent system as that is the most common cause of it blowing.
File Attachment(s):
WED5500.pdf (156kb) downloaded 3 time(s).
Collums4
#3 Posted : Friday, June 14, 2013 6:31:42 AM(UTC)
Collums4
Thanks. Yes light is on in the drum. He did switch the breaker on and off a few times yesterday. Will check the fuse. Thanks again.
jacobwilson8
#4 Posted : Monday, June 17, 2013 10:44:54 PM(UTC)
jacobwilson8
Were you able to get the dryer working?
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
