Joshmx
#1 Posted : Friday, June 7, 2013 4:55:38 PM(UTC)
Joshmx
I have Fisher & Paykel washer (model GWL15) that is giving me grief. Stopped working the other day and turned it over to we if I could see something no luck. Flipped it back over and it worked. Now it over loaded itself with water and stopped altogether. Now it's like it's not even plugged in. Tried different outlets and no luck it like it shorted out. Any ideas???
scott5495
#2 Posted : Saturday, June 8, 2013 6:21:32 AM(UTC)
scott5495
there is a tech guide in the backsplash with a diagnostic program in it. chek for water in the control panel. if water most likely shorted board. sounds like other problems from what you say started it all. most likely turning it over is what put water in the board. before replacing board, check the pump, it could cause the original problem
"The Lid is up" - Fisher & Paykel Model # DD603 Serial # BFM750387 (Dishwasher Repair)
by tkalota 5/5/2015 9:47:45 AM(UTC)
Fisher & Paykel Washer Error code 49 Help (Washer Repair)
by Mr. Cliff 9/3/2012 9:54:53 AM(UTC)
Fisher & Paykel F3 error code :0 (Dishwasher Repair)
by Forkedupdishdrawerguy 11/29/2010 8:32:09 PM(UTC)
Fisher & Paykel washer stops mid-cycle - (Washer Repair)
by Poodle Head Mikey 11/18/2010 3:03:20 PM(UTC)
Fisher & Paykel dishwasher (Dishwasher Repair)
by lsaling 6/1/2010 4:24:02 PM(UTC)
Fisher & Paykel Dishwasher (Dishwasher Repair)
by jok3rw 10/6/2009 5:17:16 AM(UTC)
Fisher & Paykel washer won't fill or drain (Washer Repair)
by sesafisher 9/11/2009 1:43:18 PM(UTC)
fisher & paykel makes squealing sound (Washer Repair)
by kojack 7/29/2009 10:33:43 AM(UTC)
Fisher & Paykel Dryer (Dryer Repair)
by redsuspender 6/2/2009 5:12:48 PM(UTC)
Fisher & Paykel - Trying to test a Bake Element (Oven Repair (including Ranges and Cooktops))
by FixitGuy 1/7/2009 5:42:54 AM(UTC)
