I got an error messesage #49. In diagnostic mode was not able to turn on hot or cold using the "how dirty" up and down arrows. When testing the pump using the Fabric care button the pump ran for one second then stopped. I checked pump for obstructions and found none. I think it is the controller, but not 100% sure. any advice?
Did you ever get resolution on this? I'm experiencing the same problem on my IWL16. I found water under the Motor controller and I suspect this fried my board. I'm assuming the water was because the nozzle was fairly corroded from hard water. I cleaned that with vinegar and ordered a new board and the rubber coupling. Crossing my fingers...
