I know this has been discussed on this forum before, but I couldn't find a thread specifically the the make and model I have.
The dryer has power, the light comes in inside the drum, but it won't start. I can also hear the timer running. I replaced the door switch, but still nothing.
Any help would be greatly appreciated.
Doug
No good... belt is still intact.
Check the belt switch (under the idler pulley).
Gene,
How do I get to that part? Does the drum need to come out?
Doug
check the little termostats on the air vent system, one may be opened. you need a mulit meter to check it.
Doug Yes, you have to disassemble the dryer. Before you'll do it, do one more test. Open the dryer door and tape in the door switch. Push and hold the start switch and manually rotate the drum. Post the result. Gene.
I cut my losses and bought one. Thanks for the help...
