dnedzesky
#1 Posted : Tuesday, April 21, 2009 3:03:40 PM(UTC)
dnedzesky
I know this has been discussed on this forum before, but I couldn't find a thread specifically the the make and model I have.
The dryer has power, the light comes in inside the drum, but it won't start. I can also hear the timer running. I replaced the door switch, but still nothing.
Any help would be greatly appreciated.
Doug
#2 Posted : Wednesday, April 22, 2009 1:05:05 PM(UTC)
Hi Doug,
The first thing I would do is check the belt. You dryer has the belt switch which is a safety device and if the belt brakes then the dryer would not do anything.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGQ8621PG0 | AppliancePartsPros.com
dnedzesky
#3 Posted : Wednesday, April 22, 2009 3:53:03 PM(UTC)
dnedzesky
Hi Doug,
Thanks Gene. I appreciate the help.
#4 Posted : Wednesday, April 22, 2009 4:28:22 PM(UTC)
dnedzesky
#5 Posted : Wednesday, April 22, 2009 4:30:18 PM(UTC)
dnedzesky
No good... belt is still intact.
#6 Posted : Wednesday, April 22, 2009 4:33:09 PM(UTC)
Check the belt switch (under the idler pulley).
dnedzesky
#7 Posted : Thursday, April 23, 2009 2:15:01 PM(UTC)
dnedzesky
Gene,
How do I get to that part? Does the drum need to come out?
Doug
peppersnow
#8 Posted : Thursday, April 23, 2009 2:35:55 PM(UTC)
peppersnow
check the little termostats on the air vent system, one may be opened.
you need a mulit meter to check it.
#9 Posted : Thursday, April 23, 2009 3:06:40 PM(UTC)
Originally Posted by: dnedzesky Go to Quoted Post
Gene,
Doug
Yes, you have to disassemble the dryer. Before you'll do it, do one more test. Open the dryer door and tape in the door switch. Push and hold the start switch and manually rotate the drum. Post the result.
dnedzesky
#10 Posted : Friday, April 24, 2009 7:00:58 PM(UTC)
dnedzesky
I cut my losses and bought one. Thanks for the help...
Guest (5)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Gas Dryer won't start (Dryer Repair)
by lowdown 10/29/2013 12:19:41 PM(UTC)
Maytag Gas Dryer Won't Start Cycle (Dryer Repair)
by dietrichnp1 8/3/2013 9:13:39 AM(UTC)
Whirlpool 29" Gas Dryer Won't Start (Dryer Repair)
by joepasq 9/5/2012 9:26:14 PM(UTC)
MAytag gas dryer won't start (Dryer Repair)
by doma135 8/24/2012 6:33:36 AM(UTC)
Whirlpool gas dryer won't start. Fuse is good (Dryer Repair)
by jeffmaaske 7/17/2012 8:38:23 PM(UTC)
bocsh gas dryer won't start (Dryer Repair)
by mbaizley 10/26/2011 12:12:28 PM(UTC)
Gas dryer won't start but makes buzz noise (Dryer Repair)
by malhs 11/9/2010 5:44:22 PM(UTC)
Gas dryer won't start when pressing start button (Dryer Repair)
by jimamy 9/13/2010 12:35:43 PM(UTC)
GE Gas Dryer won't start (Dryer Repair)
by reactionary 12/31/2009 12:59:38 PM(UTC)
Kenmore Elite Gas dryer won't start (Dryer Repair)
by stelli47 11/22/2009 7:51:22 PM(UTC)
Whirlpool gas dryer won't start (Dryer Repair)
by sewqueen 3/27/2009 3:53:54 PM(UTC)
Duet Gas Dryer won't start (Dryer Repair)
by dmoc 1/3/2009 6:41:20 AM(UTC)
