Jas O
#1 Posted : Thursday, May 23, 2013 6:53:49 PM(UTC)
Jas O
Have washer with bad clutch. Everything is apart but the shaft on the tranmission will not pull out of the washer so I can change the clutch.
I need help.
Thank you Jas O
fairbank56
#2 Posted : Thursday, May 23, 2013 7:24:28 PM(UTC)
fairbank56
Groups: Expert
Model number???
Jas O
#3 Posted : Thursday, May 23, 2013 10:13:09 PM(UTC)
Jas O
Originally Posted by: fairbank56 Go to Quoted Post
Model number???
Utlimate Care 2. 10 cycle # sn828086
fairbank56
#4 Posted : Friday, May 24, 2013 4:44:09 AM(UTC)
fairbank56
Groups: Expert
Still need the model number. If it has the fabric softener dispenser, did you remove the clip and washer from the agitator shaft? Thoroughly clean the exposed part of the agitator shaft?
Eric
Jas O
#5 Posted : Friday, May 24, 2013 6:25:23 AM(UTC)
Jas O
Eric
Yes I removed clip and washer. Model #LSQ9600JQO
Thanks Jas O
Jas O
#6 Posted : Friday, May 24, 2013 6:45:56 AM(UTC)
Jas O
Thanks Jas O
ps When I pull it out 2 or 3 in its a hard solid hit not just stuck.
fairbank56
#7 Posted : Friday, May 24, 2013 7:42:58 AM(UTC)
fairbank56
Groups: Expert
Probably rust or gunk buildup on the agitator shaft. You will have to use brute force. A helper with heavy hammer and large drift pin banging down on top of agitator shaft while you pull on the gearcase.
Eric
Jas O
#8 Posted : Friday, May 24, 2013 1:44:15 PM(UTC)
Jas O
Eric
Thanks alot it worked. Now I have a clicking noise when it first starts spining and then it goes away. It only does it at first when it starts at a slow speed and as it buildes up speed no problem
