Have washer with bad clutch. Everything is apart but the shaft on the tranmission will not pull out of the washer so I can change the clutch. I need help. Thank you Jas O
Groups ready for retrieval: Expert
Originally Posted by: fairbank56 Model number??? Utlimate Care 2. 10 cycle # sn828086
Still need the model number. If it has the fabric softener dispenser, did you remove the clip and washer from the agitator shaft? Thoroughly clean the exposed part of the agitator shaft?
Eric
Originally Posted by: fairbank56 Still need the model number. If it has the fabric softener dispenser, did you remove the clip and washer from the agitator shaft? Thoroughly clean the exposed part of the agitator shaft?
Eric Yes I removed clip and washer. Model #LSQ9600JQO Thanks Jas O
Originally Posted by: Jas O Yes I removed clip and washer. Model #LSQ9600JQO Thanks Jas O ps When I pull it out 2 or 3 in its a hard solid hit not just stuck.
Probably rust or gunk buildup on the agitator shaft. You will have to use brute force. A helper with heavy hammer and large drift pin banging down on top of agitator shaft while you pull on the gearcase.
Eric
Originally Posted by: fairbank56 Probably rust or gunk buildup on the agitator shaft. You will have to use brute force. A helper with heavy hammer and large drift pin banging down on top of agitator shaft while you pull on the gearcase.
Eric Thanks alot it worked. Now I have a clicking noise when it first starts spining and then it goes away. It only does it at first when it starts at a slow speed and as it buildes up speed no problem
