My oven is not working. Everytime I try to turn it on a beeping sound occurs and the Code F31 flashes across the screen. I looked uo the error codes and it stated that F3 is a shorted temprature sensor but what about F31? How do I go about getting this repaired? Is it simple enough for me to do? :)
Here are your parts Replacement parts for TAP TEF326FSA | AppliancePartsPros.comTemp sensor is Item 37 in the "Body" section, Item F37 near the bottom of the parts listing. Here is a good link http://www.applianceaid.com/elecrange.html Check out # 7 and #8 Looks like you should be able to just undo the screw and pull it into the oven, then undo the connector. Put a clip or something on the wires so they do not fall back behind the oven. Then check the temperature probe/sensor with a meter. Make sure the unit is unplugged when doing this. I looked uo the error codes and it stated that F3 is a shorted temprature sensor but what about F31? No idea what the 1 is. Perhaps someone else who does know will jump in. Getting tech info on Tappan is difficult. How do I go about getting this repaired? See above Is it simple enough for me to do? I do not know you so I cannot say. It is not difficult to at the minimum check the probe. If the probe is OK then it could be a shorted wire or the control board. |
THIS FORUM IS DEAD!!!!!!! |
