gettone
#1 Posted : Tuesday, October 23, 2012 6:08:08 AM(UTC)
gettone
The Door Glass Was Broken, Part # Wb36x10143. I Understand Ge Has Discontinued The Oven Model.
I Need Help In Locating Sources For The Replacement Glass Door.
Thank You.
#2 Posted : Tuesday, October 23, 2012 3:28:21 PM(UTC)
I'm not sure when it has been discontinued. In such situation only hope for you is to find a small local parts store where it might be in some dark and dusty corner. You also can try to search the net for old used range like yours for sale.
#3 Posted : Wednesday, October 24, 2012 3:10:53 AM(UTC)
Looks like this is just a glass and does not have holes etc. for the handle so you could measure where the glass fits to get the size.
Then take your tape measure and go to a few stores (Sears would be a good bet as the Kemore is from many different manufacturers), to see if you can find a front door glass on a modern unit that is the same size as yours.
Then get that model number and see what a replacement is going to cost.
Just be sure it is not bigger, slightly smaller should be OK.
1960's Oven Repair - Need model # (Oven Repair (including Ranges and Cooktops))
by jarla 12/13/2020 10:48:51 AM(UTC)
GE oven repair (Oven Repair (including Ranges and Cooktops))
by arshlo 12/10/2016 7:51:10 AM(UTC)
Oven Repair (Oven Repair (including Ranges and Cooktops))
by ridenroaddog 12/9/2013 11:06:59 AM(UTC)
by ANTHONYMAYWEATHERS 8/5/2013 4:45:40 PM(UTC)
by miguel 2 4/14/2013 10:06:22 AM(UTC)
Frigidaire Oven Repair Problem (Oven Repair (including Ranges and Cooktops))
by PetraMarion 2/25/2013 4:58:33 AM(UTC)
by johnthrasher45 2/9/2013 12:04:31 PM(UTC)
by johnthrasher45 2/8/2013 10:04:38 AM(UTC)
Oven repair (Oven Repair (including Ranges and Cooktops))
by johnthrasher45 2/8/2013 3:57:12 AM(UTC)
by johnthrasher45 2/7/2013 11:59:12 AM(UTC)
Questioning my first Oven Repair (Oven Repair (including Ranges and Cooktops))
by morbe 1/4/2013 1:18:05 PM(UTC)
by artalba 12/16/2012 5:07:10 PM(UTC)
GE Oven Repair Question? (Oven Repair (including Ranges and Cooktops))
by ejprap 11/7/2012 4:30:59 AM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
by Barb129 9/10/2012 12:03:34 PM(UTC)
