rececheeks
#1 Posted : Wednesday, April 22, 2009 4:46:26 PM(UTC)
rececheeks
My oven is not working. Everytime I try to turn it on a beeping sound occurs and the Code F31 flashes across the screen.
I looked uo the error codes and it stated that F3 is a shorted temprature sensor but what about F31?
How do I go about getting this repaired?
Is it simple enough for me to do?
#2 Posted : Thursday, April 23, 2009 4:32:19 AM(UTC)
Replacement parts for TAP TEF326FSA | AppliancePartsPros.com
Temp sensor is Item 37 in the "Body" section, Item F37 near the bottom of the parts listing.
Here is a good link
http://www.applianceaid.com/elecrange.html
Check out # 7 and #8
Looks like you should be able to just undo the screw and pull it into the oven, then undo the connector. Put a clip or something on the wires so they do not fall back behind the oven. Then check the temperature probe/sensor with a meter.
Make sure the unit is unplugged when doing this.
No idea what the 1 is. Perhaps someone else who does know will jump in. Getting tech info on Tappan is difficult.
See above
I do not know you so I cannot say. It is not difficult to at the minimum check the probe. If the probe is OK then it could be a shorted wire or the control board.
1960's Oven Repair - Need model # (Oven Repair (including Ranges and Cooktops))
by jarla 12/13/2020 10:48:51 AM(UTC)
GE oven repair (Oven Repair (including Ranges and Cooktops))
by arshlo 12/10/2016 7:51:10 AM(UTC)
Oven Repair (Oven Repair (including Ranges and Cooktops))
by ridenroaddog 12/9/2013 11:06:59 AM(UTC)
by ANTHONYMAYWEATHERS 8/5/2013 4:45:40 PM(UTC)
by miguel 2 4/14/2013 10:06:22 AM(UTC)
Frigidaire Oven Repair Problem (Oven Repair (including Ranges and Cooktops))
by PetraMarion 2/25/2013 4:58:33 AM(UTC)
by johnthrasher45 2/9/2013 12:04:31 PM(UTC)
by johnthrasher45 2/8/2013 10:04:38 AM(UTC)
Oven repair (Oven Repair (including Ranges and Cooktops))
by johnthrasher45 2/8/2013 3:57:12 AM(UTC)
by johnthrasher45 2/7/2013 11:59:12 AM(UTC)
Questioning my first Oven Repair (Oven Repair (including Ranges and Cooktops))
by morbe 1/4/2013 1:18:05 PM(UTC)
by artalba 12/16/2012 5:07:10 PM(UTC)
GE Oven Repair Question? (Oven Repair (including Ranges and Cooktops))
by ejprap 11/7/2012 4:30:59 AM(UTC)
by gettone 10/23/2012 6:08:08 AM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
