AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Washing Machine fills, and drains but does not Agitate/Spin
Help will be greatly appreciated...
Did you check the drive belt?
Yes It's In Great Condition
Groups: Expert
Check the lid switch, check for error codes using the flashing LED on top right side of motor inverter board.
Eric
Eric,
The green LED light on the motor inverter board flashes once every second.
Groups: Expert
If the lid switch checks ok, take some voltage checks on the rightmost connector on the inverter board using the following table. There should be 120vac on two wires depending on mode and speed selection. C2 pin 3 is on the left connector and is neutral. If the voltages check out ok, then you have a bad motor/inverter. Eric
Washer Repair
