Where's the EASY BUTTON
#1 Posted : Monday, May 13, 2013 5:37:42 PM(UTC)
Help will be greatly appreciated...
#2 Posted : Tuesday, May 14, 2013 2:26:09 PM(UTC)
any ideas?
Ladderdaddy
#3 Posted : Tuesday, May 14, 2013 5:56:21 PM(UTC)
Ladderdaddy
Did you check the drive belt?
#4 Posted : Tuesday, May 14, 2013 8:24:16 PM(UTC)
Yes It's In Great Condition
fairbank56
#5 Posted : Wednesday, May 15, 2013 4:52:13 AM(UTC)
fairbank56
Groups: Expert
Check the lid switch, check for error codes using the flashing LED on top right side of motor inverter board.
Eric
#6 Posted : Thursday, May 16, 2013 2:56:03 PM(UTC)
Eric,
The green LED light on the motor inverter board flashes once every second.
fairbank56
#7 Posted : Thursday, May 16, 2013 3:16:53 PM(UTC)
fairbank56
Groups: Expert
If the lid switch checks ok, take some voltage checks on the rightmost connector on the inverter board using the following table. There should be 120vac on two wires depending on mode and speed selection. C2 pin 3 is on the left connector and is neutral. If the voltages check out ok, then you have a bad motor/inverter.
Eric
UserPostedImage
