hawknic
#1 Posted : Sunday, May 5, 2013 6:31:59 AM(UTC)
hawknic
My gas dryer glows for 10 -15 seconds then it clicks and does not ignite.
It tries again in another minute. I can smell gas so I turn it off.
I replaced the coils and it does the same thing. Could it be the gas valve and I could I check the valve. There is no lint build up any where.
ApplianceJunk
#2 Posted : Sunday, May 5, 2013 7:45:08 AM(UTC)
ApplianceJunk
I would check the thermal fuse first.
hawknic
#3 Posted : Sunday, May 12, 2013 7:13:35 AM(UTC)
hawknic
I checked the thermal fuse. What would be the next step? Could the gas valve bot be opening properly?
hawknic
#4 Posted : Sunday, May 12, 2013 8:59:08 AM(UTC)
hawknic
Ok I replaced coils, ignitor is good ( 80 ohms) the flame sensor good. Dryer glows but no ignition. Any ideas? Thank you
ps looked at new dryers..ouch would like to repair old one.
scott5495
#5 Posted : Sunday, May 12, 2013 9:36:39 AM(UTC)
scott5495
even though the ignitor checks good, it can still be bad. i have found that ignitors will read good until they begin to draw amperage. an ignitor can have a small crack in it and still glow. the ignitor must draw at least three amps to activate the coils to open the gas valve. one of the coils is a holding coil. did you replace both coils?
hawknic
#6 Posted : Thursday, May 16, 2013 4:04:05 AM(UTC)
hawknic
Yes I replaced both coils. I am going to replace the ignitor. I was told that when they get into the 90 ohm reading to replace. I can smell gas so I don't think it's the valve. Thank you Scott5495 appreciate the reply it reinforces decision.
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Samsung dryer no heat - 5 possible components? (Dryer Repair)
by sgsiegel 2/11/2018 7:02:33 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Maytag Atlantic Dryer no heat but everything tests ok (Dryer Repair)
by oldebrowndog 11/10/2015 11:38:46 AM(UTC)
Dryer No Heat.mind boggling! (Dryer Repair)
by andrelaplume 10/10/2015 7:22:06 PM(UTC)
by fhorta 9/28/2015 12:22:36 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
hot point dryer no heat and timer doesn't advance (Dryer Repair)
by gooseofdeuce 4/18/2015 8:29:56 AM(UTC)
by SEMIFAST0 3/15/2015 9:00:11 AM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
