Rank:: Member
I went to use my oven a couple of days ago. I pushed the button to turn it on and immediately heard a "bzzt" noise (electronic shorting sound) come from the vicinity of the clock/control panel. The screen then went out and I am unable to turn on the oven. The interior light and stovetop, however, are still functional. I am trying to determine which part I need to repair this problem a) Oven Control Board #316101008, b) Relay #316113700 or Circuit Board #318111400. Or maybe it is something else altogether ??
Groups: APP Team
Hi.
If you feel comfortable to run voltage test using the multimeter then : -unplug the range -get access to the control board/oven clock -remove the wire from DLB contact and make sure it's not touching any metal surface -plug in the range -check for 120VAC between L1 and N -if there is a proper voltage then the control board is bad And that's where the problem starts. The clock/control board is no longer available.
Simon.
Rank:: Member
Thank you for your help Simon !
Groups: APP Team
