Replacement parts for JRP14GT models | AppliancePartsPros.comAs usual I cannot find any tech info, GE likes to keep that info a secret.
I see 2 limit switches in the unit but I cannot say what they are for.
One is probably for the fan.
The other may be for the element/s or the control board.
Remove power from the unit and check them with a meter, both should be 0 ohms (I think).
Odds are high that the control board is toast but check other things first.
First check that all wiring in the unit is OK.
Then, I would check that you are getting the correct power to the unit.
I am assuming this is a 3 wire hookup.
The clock will probably use half the line 120 while the elements will use the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
