mburke615
#1 Posted : Monday, April 15, 2013 11:39:06 AM(UTC)
mburke615
I have a GE Profile Fridge PDS22SBPARSS.
I have a defrost problem. Heater and thermodisk are OK. (I can manually power the heating element to defrost.) Already replaced the mother board 3 months ago. (Also had a condenser fan problem that fixed along with fan replacement) but I have had the cold freezer warm fridge problem for some time too. Worked fine until humidity level of spring. Evaporator freezes over, ice blocks evap fan into fridge. Manually defrosting temporarily solves problem. Question: Can the freezer thermistor be bad for the defrosting cycle but still read accurate temps on the display of the fridge? Or are there separate sensors for each? Evap fan runs full speed when failing to cool fridge. Stops when open freezer door too long and runs at normal speed after manual defrost cycle.
#2 Posted : Monday, April 15, 2013 6:15:53 PM(UTC)
Hello,
There is a second thermistor in the freezer which is located on top of the evaporator coils. This thermistor controls the defrost cycle and very likely caused this problem.
- The thermistor Part number: WR55X10025
Guest (4)
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer (Refrigerator & Freezer Repair)
by jhmon 5/29/2020 12:20:04 AM(UTC)
Freezer cold, fridge warm Whirlpool (Refrigerator & Freezer Repair)
by Debma 1/25/2016 11:09:49 PM(UTC)
freezer cold, fridge warm, damper closed tite (Refrigerator & Freezer Repair)
by thecac 7/11/2012 11:25:55 AM(UTC)
Freezer cold, fridge warm (Refrigerator & Freezer Repair)
by spartom 7/3/2012 5:11:47 PM(UTC)
GE freezer cold, fridge warm (Refrigerator & Freezer Repair)
by dsandwich 7/1/2012 1:21:45 PM(UTC)
Freezer cold, fridge warm, unit constantly running (Refrigerator & Freezer Repair)
by mista_eng 5/30/2011 8:14:22 PM(UTC)
by Sunshineoeff 9/8/2010 7:03:58 AM(UTC)
Freezer cold, fridge warm - please help !! (Refrigerator & Freezer Repair)
by aviator2010 9/25/2009 10:02:45 AM(UTC)
