1dog
#1 Posted : Saturday, March 23, 2013 1:25:58 PM(UTC)
1dog
I have q whirlpool washer model 110.28812790 My wife noticed water on floor small puddle(1/2 cup?) I could not duplicte.I had some time, so I pulled unit out and noticed drain pump was/had been leaking replaced pump/drain and coupler reassembled started with cover off and smelled motor getting hot(did noticed before replacing drain/pump/coupler) replaced motor(Found one used free) now everything works until it goes into spin/rinse, drain pumps out etc when I raise and lower lid it will start to spin during cycle I'm at a loss! If anybody can help would be very greatful Thanks
fairbank56
#2 Posted : Saturday, March 23, 2013 3:04:08 PM(UTC)
fairbank56
Groups: Expert
The washer has a neutral drain transmission. After agitation cycle ends, it should drain without spinning. After draining, the motor should pause for a few seconds (releases neutral drain) and then start again draining and spinning. If the motor doesn't pause after drain, the timer is defective. By opening and closing the lid, you are pausing the motor.
Eric
1dog
#3 Posted : Sunday, March 24, 2013 6:10:54 AM(UTC)
1dog
Eric
Thanks for the info! I tried to find info on at what point should it pause how many seconds etc (timer chart) into drain cycle no luck but it is not pausing so i guess i will order timer! thanks again
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Drains - No Spin (Washer Repair)
by Pallas63 5/20/2022 5:19:47 PM(UTC)
Electolux/Frigidaire fftw4120sw1 agitates, no spin. (Washer Repair)
by wishy_washy 11/19/2021 10:02:42 AM(UTC)
Slow to no spin maytag bravos (Washer Repair)
by Guest 7/28/2021 12:13:49 PM(UTC)
Kenmore Frontload No Spin, but does 2 second fluff spin? (Washer Repair)
by d44boy 3/4/2019 10:18:00 AM(UTC)
Horrible noise and no spin (Washer Repair)
by wilkimtur1 7/19/2018 10:18:41 AM(UTC)
No spin after first one (Washer Repair)
by Jimbobaloue 3/15/2018 1:40:45 PM(UTC)
Whirlpool Gold Ultimate Care II Agitates but no spin (Washer Repair)
by MikeyVdub 1/8/2018 12:49:57 PM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
Agitates and drains but no spin (Washer Repair)
by Burgerpimp 6/7/2017 10:14:27 AM(UTC)
Kenmore 800 Washer no spin on delicate cycle spins fine on others (Washer Repair)
by tedalb 3/27/2017 7:29:52 PM(UTC)
Whirlpool Washer Agitator Noise / No Spin (Washer Repair)
by BobTh 3/1/2017 11:06:09 AM(UTC)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
Agitate but no Spin - Brake has lots of grease on it. (Washer Repair)
by movinglikeamovie 8/15/2016 2:27:22 PM(UTC)
Just Humming,No spin,no agitate (Washer Repair)
by buddha131 5/10/2016 3:07:32 PM(UTC)
