Help, Our Trio is not working at all! First the freezer went then the fridge...that was two days total.. We've cleaned out from underneath to clear the coils and what not...are there any "resets" to this machine that anyone knows of? I cannot afford to get it fixed or replaced for another two weeks.
Check to see if the condenser fan at the back underneath the fridge is running. Is the compressor motor near that fan running. Are the coils warm ,cold or hot.
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere.
