Fairly new Kenmore Elite Trio fridge with bottom freezer. Had a spill and doors open for extended period of time last night. Now the lights will not come on when doors are opened. Replaced the bulbs just in case and still nothing... any ideas...? :confused:
Freezer light comes on....
Help. I did a search a seemed like the likey culprit was the door switchs. I ordered 2 new ones and just installed... still dont work. It I quickly excersie the left door swith the buld flickers....
ideas...???
No one have any ideas? Guess I call Sears... :(
Did you ever find out what the problem was? I have the same fridge and I'm having light issues also.
They replaced the circuit board. Its covered under a extended warrenty due to a recall on the part
Not sure if we have the same model, I am interested to know if mine has a recall. My model number is 596.73503200, is yours the same? Originally Posted by: JMCFAN They replaced the circuit board. Its covered under a extended warrenty due to a recall on the part
