Phung Luong
#1 Posted : Thursday, March 7, 2013 10:30:00 PM(UTC)
Phung Luong
My refrigerator has the same symptom the 2nd time since I bought it in 2007. The freezer temperature was about 4 or 5 degrees and the refrigerator side temp was above 50 and could never go any lower even it is set at 37 degree. The very top compartment and the 3rd compartment from the bottom froze up food.The first time was the big fan in the Cover Evaporator ASM (part # WR17X11915) did not work, I replaced the the whole kit and it worked great ever since.
The similar problem happened at this time so I took the Cover Evaporator ASM and check both fans in this kit, they worked just fine with a 12VDC external power supply. Then I checked both cable connectors which are connected to the big fan and the small motor fan. I had 12-13 Vdc at the connector for the big fan and only had about 2Vdc for the small motor fan. I am not sure if the 12 Vdc for both fans coming from the same source which is the main control board WR49X10147. I tried to check J3 pin 1 and 2, J3 pin 3 and 4 to look for the 12 VDC but I did not get any and I didn't think I probed at the correct cables at the control board for. Please let me know if the problem is from the main control board or should I check the thermostat first.
Thank you,
Phung Luong
#2 Posted : Friday, March 8, 2013 5:26:08 PM(UTC)
Hello Phung Luong,
There is only one evaporator fan motor in the refrigerator which comes as a part of the evaporator cover. You probably call it "big fan". The fan you called "small fan" is probably belongs to the Custom cool part of the refrigerator. This fan activates only when you use the Custom cool.
If you would like to verify power to the evaporator fan motor, you can do it by measuring the DC voltage between the pins J2-6 and J2-8 at the main control board. Post the results.
Here are the breakdown diagrams and Parts for GE PSS26PSTASS Refrigerator - AppliancePartsPros.com
P.S. The mini-manual is attached to the post.
File Attachment(s):
31-51677 - PSS26PSTASS.pdf (921kb) downloaded 7 time(s).
Phung Luong
#3 Posted : Saturday, March 9, 2013 12:25:07 PM(UTC)
Phung Luong
Hi Gene,
Thank you for your reply. I checked the control board at between J2 pin 6 and J2 pin 8 I had about 9VDC. I also checked all the thermistors at connector J1 from pin1 and gnd at pin5=20.2K Ohms, J1 pin2 to J1 pin5=14.7K Ohms,J1 pin3 to J1 pin5=15.7K Ohms, J1 pin 4 to J1 pin5=16.15K Ohms. The motor fan worked outside the frig when I plug it in the 12VDC power supply. Please let me know what elsi I should check.
:mad:
#4 Posted : Monday, March 11, 2013 1:11:58 PM(UTC)
The voltage test result points to a bad main control board.
To test the thermistors it is very important to measure the exact temperatures at the same time.
- The main control board Part number: WR49X10152
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 11/9/2022 4:07:46 PM(UTC)
Kenmore Elite side by side refrigerator (Refrigerator & Freezer Repair)
by jfortner 6/18/2022 7:38:51 AM(UTC)
Just bought new side by side refrigerator but doesn't get cold enough (Refrigerator & Freezer Repair)
by Hotlynx16 3/28/2022 2:47:44 PM(UTC)
Admiral side by side refrigerator external drip drain tray (Appliance Parts)
by Paul Bridges 1/14/2021 10:28:34 AM(UTC)
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
GE Profile Side by Side Refrigerator Model ESS25XGMB (2001) not cooling (Refrigerator & Freezer Repair)
by boxer 7/14/2019 7:19:21 PM(UTC)
Kenmore side by side refrigerator keep running (Refrigerator & Freezer Repair)
by Xmwwang 2/21/2019 7:14:22 PM(UTC)
side by side refrigerator started clicking and humming (Refrigerator & Freezer Repair)
by mjkneiser 6/28/2018 8:18:44 AM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
Side by side refrigerator keeps turning on and off (Refrigerator & Freezer Repair)
by Rasenganguy 9/27/2016 6:43:34 PM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
Fridge and freezer too warm in my side by side refrigeratorld enough (Refrigerator & Freezer Repair)
by Majdo 9/17/2015 11:52:33 AM(UTC)
Side by side refrigerator not cooling. (Refrigerator & Freezer Repair)
by Jms55 1/26/2015 12:24:12 PM(UTC)
GE side by side refrigerator not holding temperature (Refrigerator & Freezer Repair)
by Jmatthew33 7/8/2014 8:06:56 PM(UTC)
