cdmason7
#1 Posted : Thursday, March 7, 2013 7:54:42 AM(UTC)
cdmason7
My washer all of a sudden started making a horrible screeching/buzzing noise at the end of the wash cycle, when trying to go into the drain/spin cycle. It will still operate fine during wash or rinse, but won't drain or spin
Joe / APP Team
#2 Posted : Thursday, March 7, 2013 10:18:05 AM(UTC)
Joe / APP Team
CD, Your post description, leads us to believe you have a drain pump issue
Part number: AP4035317
The screeching/buzzing noise and no drain, would indicate the assembly has failed or may be clogged with debris. The pump is located in the right rear corner of the base area, you'll need to slide the washer out, remove the rear access panel, and the assembly will be located on the left side of the opening , down on the base.
Dryer making loud buzzing/screeching noise intermittently (Dryer Repair)
by tvaber 8/18/2018 5:40:29 PM(UTC)
Frigidaire washer - loud screeching noise at start of spin cycle (Washer Repair)
by Shrimpzilla 4/8/2015 10:25:33 AM(UTC)
Grinding/Screeching Noise in GE Profile Harmony (Washer Repair)
by douglasazo 10/13/2014 9:37:11 AM(UTC)
Dryer screeching noise - some parts already replaced (Dryer Repair)
by Judy Cz 7/11/2014 7:15:57 AM(UTC)
Kenmore washer Mod 110 grinding/screeching noise (Washer Repair)
by clarkeb 8/10/2012 1:38:01 PM(UTC)
Loud high pitched screeching noise (Dryer Repair)
by hayleas_mommy 1/15/2012 2:58:28 PM(UTC)
Screeching noise (Dryer Repair)
by detwiler 12/27/2011 11:54:54 AM(UTC)
Dryer Making Screeching Noise (Dryer Repair)
by mhc1963 10/19/2010 3:55:21 AM(UTC)
Random Screeching noise (Washer Repair)
by Cathyw46 3/8/2010 7:59:15 AM(UTC)
hotpoint dryer making screeching noise (Dryer Repair)
by kight57 10/26/2009 6:52:29 AM(UTC)
by cerenity 2/12/2009 6:47:23 PM(UTC)
Electric dryer making screeching noise (Dryer Repair)
by Windsurfer 7/9/2008 10:18:30 PM(UTC)
top load amana screeching noise (Washer Repair)
by steeler82 6/21/2008 12:58:24 PM(UTC)
