ctmalone
#1 Posted : Saturday, April 18, 2009 8:02:03 AM(UTC)
ctmalone
When starting the dryer, heard a clunking noise(belt)?. Then I restarted it and just get motor noise/ load humming, but drum doesn't turn.
If it sounds like belt, how do I replace it?
Thanks,
Tim
sidfink43
#2 Posted : Saturday, April 18, 2009 3:32:01 PM(UTC)
sidfink43
Ok, they don't make it particularly easy for you on this model, but it is really a matter of patience and perserverance. I suggest some help to hold the drum during the process. Also make sure you understand how the belt goes on and is held tight by the tension roller.
1. Remove the bottom service panel by removing two screws near the bottom of the panel. You can now look inside and determine that the belt is indeed broken.
2. Remove the front panel, making sure you disconnect the door switch. Make sure you reconnect the door switch on reassemby.
3. Remove the front bulkhead assemby which holds the drum. This is the place where it is handy to have a helper hold the drum.
4. Put you new belt on, then put the front bulkhead assemby back on.
5. Press on the tension roller and get the belt on the motor pulley.
6. Reassemble and you should be set to go.
kayakcrzy
#3 Posted : Sunday, April 19, 2009 4:29:15 AM(UTC)
kayakcrzy
Don't forget to unplug it first. The old lady might enjoy the insurance policy. LOL!!! Tom ApplianceEducator.com
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Amana electric dryer model NED4800VQ1 (Dryer Repair)
by thorning 9/22/2022 8:05:59 AM(UTC)
Amana electric dryer (Dryer Repair)
by thorning 5/20/2017 4:02:54 AM(UTC)
Amana Electric Dryer Buzzing Sound (Dryer Repair)
by amanabert 5/12/2012 11:48:31 AM(UTC)
Amana Electric Dryer Miswired? (Dryer Repair)
by lacer8 10/26/2011 10:01:30 PM(UTC)
Amana Electric Dryer runs for a while. (Dryer Repair)
by Pyro 9/19/2011 6:43:49 PM(UTC)
Amana Electric Dryer Won't Heat (Dryer Repair)
by RandyMarthaKatieNutmeg 6/13/2011 11:44:46 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
by james oteri 12/20/2010 1:50:22 PM(UTC)
Amana electric dryer won't heat (Dryer Repair)
by johnbharvey 7/2/2010 2:31:46 PM(UTC)
Amana electric dryer - no heat (Dryer Repair)
by TimInOhio 10/15/2009 12:05:13 AM(UTC)
need instructions for replacing the rollers and beltfor a amana electric dryer (Dryer Repair)
by bigun 9/9/2009 6:59:42 AM(UTC)
Amana Electric Dryer makes noise (Dryer Repair)
by SVCtech 7/16/2009 12:59:30 PM(UTC)
