james oteri
#1 Posted : 14 years ago
james oteri
We try to start the dryer, seems like the motor does not have enough power to turn drum, especially when we put wet clothes in.
We held the stop button in(which is on the door frame) with tape so we could turn the drum manually when the door is open, to start cycle.
At first it helped to start the drum.
Now it is harder to start and is getting more difficult to start .
Does the motor get weak over time?
If so can the motor be replaced and is it worth spending the money to fix it?
What would it cost with shipping to ship to Bridgewater, Ma 02324
Or could there be something else besides the motor to cause this problem?
Thank You
Jim
jdoteri@aol.com
#2 Posted : 14 years ago
Here are your parts breakdown
Replacement parts for AMANA LE7153WM DRYER- ELE | AppliancePartsPros.com
[COLOR="Blue"]Does the motor get weak over time?[/COLOR]
Yes it can.
[COLOR="Blue"]If so can the motor be replaced and is it worth spending the money to fix it?
What would it cost with shipping to ship to Bridgewater, Ma 02324[/COLOR]
Whether it is worth it or not depends on what shape the dryer is in.
See the parts breakdown and then give AppliancePartsPros a call.
It looks like a replacement motor may not be available for this unit.
I do not work for them so do not have the above info.
Check to see if you can get a motor. if not then you will need to buy a new unit.
If yes, then I would open the unit up and check all moving parts, the front glides, the belt, seals etc. for wear and bearing slop. Odds are good that you may need additional parts so the cost may be higher than just a motor.
You might as well do an overhaul while you have it opened up.
Also remove the motor from the unit before ordering one. Many units use a screw on blower wheel which often seizes onto the motor shaft and has to be broken to remove the motor. So you may also have to order a blower wheel increasing your costs.
Before any of the above I would check that the drum rotates fairly easily.
You may want to try this on a couple other units to get a feel for it.
Also try rotating it with some downward pressure on the drum. Perhaps you will get lucky and only the front glides have to be replaced (too much drag on the motor). Though usually you will hear metal on metal when they go.
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 10 months ago
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 11 months ago
Amana electric dryer not working (Dryer Repair)
Amana electric dryer model NED4800VQ1 (Dryer Repair)
by thorning 3 years ago
Amana electric dryer (Dryer Repair)
by thorning 8 years ago
Amana Electric Dryer Buzzing Sound (Dryer Repair)
by amanabert 13 years ago
Amana Electric Dryer Miswired? (Dryer Repair)
by lacer8 13 years ago
Amana Electric Dryer runs for a while. (Dryer Repair)
by Pyro 14 years ago
Amana Electric Dryer Won't Heat (Dryer Repair)
by RandyMarthaKatieNutmeg 14 years ago
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 14 years ago
Amana electric dryer won't heat (Dryer Repair)
by johnbharvey 15 years ago
Amana electric dryer - no heat (Dryer Repair)
by TimInOhio 15 years ago
need instructions for replacing the rollers and beltfor a amana electric dryer (Dryer Repair)
by bigun 16 years ago
Amana Electric Dryer makes noise (Dryer Repair)
by SVCtech 16 years ago
Amana Electric Dryer (Dryer Repair)
by ctmalone 16 years ago
