22 Pages«<1819202122>
#191 Posted : Thursday, January 31, 2013 12:41:26 PM(UTC)
You are welcome. But I do not think the voltage over 13 VDC is a good reading. You may want to check it at the control board too.
freddyrick
#192 Posted : Monday, February 4, 2013 4:51:03 AM(UTC)
freddyrick
Gene, you are correct and thank you. The voltage output at R and Y was up to 19.5vdc. I bought a new motor, but instead of installing it, I tested the resistance and it read the same as the old motor, although each reading was polarity specific. I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter. Why is this? Also, the old motor still runs for a couple of seconds when first plugged in. So, I'm guessing its the motherboard. Wish I knew better how to test the motherboard before buying a new one.
#193 Posted : Monday, February 4, 2013 10:04:24 PM(UTC)
...although each reading was polarity specific. I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter...
I never heard about such things. Check how is your ohmmeter set.
freddyrick
#194 Posted : Monday, February 11, 2013 4:34:05 AM(UTC)
freddyrick
Everything is set correctly. Could it be because this is a variable speed induction motor?
#195 Posted : Monday, February 11, 2013 3:09:36 PM(UTC)
What kind of meter did you use?
freddyrick
#196 Posted : Tuesday, February 12, 2013 8:14:33 AM(UTC)
freddyrick
Basic digital ohmmeter.
#197 Posted : Tuesday, February 12, 2013 5:36:44 PM(UTC)
...I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter...
What was the difference?
How good is the battery in your meter?
Have you replaced the main control board yet?
freddyrick
#198 Posted: : Wednesday, February 13, 2013 11:28:33 AM(UTC)
freddyrick
I just got a new board to go with the new motor, and will install them together and hope for the best. Thanks.
#199 Posted : Wednesday, February 13, 2013 6:57:52 PM(UTC)
You are welcome. Both new parts together should fix it.
freddyrick
#200 Posted : Tuesday, April 2, 2013 6:50:33 AM(UTC)
freddyrick
Hello again. Installed both parts and it worked fine for over a month. Yesterday I found the evaporator coil all frosted up. Defrosted with the blow dryer, seems to be working OK again. Any ideas what might have caused the coil to frost up? Thanks.
