22 Pages«<1819202122>
#191 Posted : Thursday, January 31, 2013 12:41:26 PM(UTC)
You are welcome. But I do not think the voltage over 13 VDC is a good reading. You may want to check it at the control board too.
freddyrick
#192 Posted : Monday, February 4, 2013 4:51:03 AM(UTC)
freddyrick
Gene, you are correct and thank you. The voltage output at R and Y was up to 19.5vdc. I bought a new motor, but instead of installing it, I tested the resistance and it read the same as the old motor, although each reading was polarity specific. I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter. Why is this? Also, the old motor still runs for a couple of seconds when first plugged in. So, I'm guessing its the motherboard. Wish I knew better how to test the motherboard before buying a new one.
#193 Posted : Monday, February 4, 2013 10:04:24 PM(UTC)
...although each reading was polarity specific. I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter...
I never heard about such things. Check how is your ohmmeter set.
freddyrick
#194 Posted : Monday, February 11, 2013 4:34:05 AM(UTC)
freddyrick
Everything is set correctly. Could it be because this is a variable speed induction motor?
#195 Posted : Monday, February 11, 2013 3:09:36 PM(UTC)
What kind of meter did you use?
freddyrick
#196 Posted : Tuesday, February 12, 2013 8:14:33 AM(UTC)
freddyrick
Basic digital ohmmeter.
#197 Posted : Tuesday, February 12, 2013 5:36:44 PM(UTC)
...I got two different readings on R/W at the new motor when I reversed polarity of the ohmmeter...
What was the difference?
How good is the battery in your meter?
Have you replaced the main control board yet?
freddyrick
#198 Posted : Wednesday, February 13, 2013 11:28:33 AM(UTC)
freddyrick
I just got a new board to go with the new motor, and will install them together and hope for the best. Thanks.
#199 Posted : Wednesday, February 13, 2013 6:57:52 PM(UTC)
You are welcome. Both new parts together should fix it.
freddyrick
#200 Posted : Tuesday, April 2, 2013 6:50:33 AM(UTC)
freddyrick
Hello again. Installed both parts and it worked fine for over a month. Yesterday I found the evaporator coil all frosted up. Defrosted with the blow dryer, seems to be working OK again. Any ideas what might have caused the coil to frost up? Thanks.
Guest (14)
