Need help with a oven. Put new heating elements in and it still no t working.
I cannot find find any info on the given model number, please check it.
All the units I find have 3 letters at the end not 2.
If the stove top elements work OK and the wiring from/to the elements from the control board is OK then odds are that your control board is shot. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  I cannot find find any info on the given model number, please check it.
If the stove top elements work OK and the wiring from/to the elements from the control board is OK then odds are that your control board is shot. The model number is FEFL79HBB
