the water level does not work properly set at high level and it shuts off with less then min amount of water must reset to high every time till right amount of water is in washer.
Hello, Make sure there is no water in the washer. Open the control panel and disconnect the pressure hose (clear plastic tube) from the water level switch. Blow some air through the hose to make sure it is clear. Reconnect the hose and give it a try. If it would not help, replace the water level switch. - The water level switch Part number: W10339334
