korean1
#1 Posted : Friday, January 25, 2013 5:42:06 PM(UTC)
korean1
Came home to find cooling issues. Backwal of freezer has frost and ice maker has had issues for a little while. Not making proper ice.
And Fridge is not cooling good either.
I have been just keeping condensor fan and lines cleaned from dust.
Thoughts on correction?
#2 Posted : Saturday, January 26, 2013 3:41:36 AM(UTC)
You have a mechanical type defrost timer usually behind the control panel. Look for a hole and stick a flat bladed screwdriver in it and turn it till the compressor turns off. If you get no defrost action, you most probably have a bad defrost limiter clipped to the top of the evaporator. If you get defrost, replace the timer.
korean1
#3 Posted : Saturday, January 26, 2013 6:14:31 AM(UTC)
korean1
found the plastic non reversing style head screw. turned till the compressor kicked off. hopefully defrost!
replacing the timer i guess will be my next thing. should i expect more issues? is this sign?
THANKS FOR THE HELP. My #1 place to get information and parts!
korean1
#4 Posted : Saturday, January 26, 2013 3:53:52 PM(UTC)
korean1
Well, never defrosted. So opened up back wall. Found broken glass sleeve from element and finding thermostat bad. So replaceing asap! I think Timer is good. So hopefully this will get it.
Refrig cooling issues (Refrigerator & Freezer Repair)
by BillyTanksley 11/10/2017 10:23:21 AM(UTC)
Whirlpool Side By Side Cooling Issues Need Advice....... (Refrigerator & Freezer Repair)
by CaptainWarmFridge 6/22/2014 1:58:09 PM(UTC)
Fridge and Freezer intermittent cooling issues (Refrigerator & Freezer Repair)
by mojojojo 4/18/2014 5:25:25 PM(UTC)
Freezer/Refigerator Cooling Issues (Refrigerator & Freezer Repair)
by jimbolina 5/7/2012 7:08:33 AM(UTC)
Intermittent Cooling Issues (Refrigerator & Freezer Repair)
by jondurst 6/6/2011 8:50:31 AM(UTC)
GE Refrigerator Intermittent Cooling Issues - Help! (Refrigerator & Freezer Repair)
by ucbedge 9/12/2010 3:49:09 PM(UTC)
Roper cooling issues after freezer overload (Refrigerator & Freezer Repair)
by jshalosky 5/27/2010 5:35:58 PM(UTC)
freezer cooling issues (Refrigerator & Freezer Repair)
by mindraven 7/25/2009 8:52:03 AM(UTC)
