racer35j
#1 Posted : Wednesday, January 16, 2013 2:35:06 PM(UTC)
racer35j
Okay I'm new to the site as well as appliance repair my question is about the machine not washing? It will do the initial fill but won't wash, I took the motor out and tested it it works I was told the pump may be bad where is that and how would I check that?
#2 Posted : Thursday, January 17, 2013 2:11:43 PM(UTC)
Did it make any noise when it should wash?
Did it drain?
Which motor did you remove?
Here are the breakdown diagrams and Parts for Frigidaire FDB520RHB0 Dishwasher - AppliancePartsPros.com
racer35j
#3 Posted : Thursday, January 17, 2013 2:32:28 PM(UTC)
racer35j
It does make a whining noise when it should be washing I took the motor on the bottom center out number 70 in the diagram it functioned properly on a bench test, the unit drains with no problems as well.
#4 Posted : Friday, January 18, 2013 12:29:15 PM(UTC)
Would the spray arms spin if you will open the door during the wash cycle?
Remove the toe panel and check if the motor which you removed earlier is working?
racer35j
#5 Posted : Friday, January 18, 2013 10:24:07 PM(UTC)
racer35j
The spray arms do not spin, as for removing the toe kick and checking the motor it is getting power and works off of the machine. I guess I'm not sure how to check it on the machine? Does the drain pump act as the spray/wash pump as well?
jenniferatkins
#6 Posted : Saturday, January 19, 2013 12:49:39 AM(UTC)
jenniferatkins
If you are not sure how to check the drain pump or any other washer parts of your Frigidaire washing machine then don't try to repair it your self. It will be better if you call a expert repairman for repairing. He is solve your problem very well. I want to add one thing your washer belt may be crack or damaged. It may have to be replace.
#7 Posted : Monday, January 21, 2013 12:47:19 PM(UTC)
Originally Posted by: racer35j Go to Quoted Post
...The spray arms do not spin...
...as for removing the toe kick and checking the motor it is getting power and works off of the machine...
Open the door during the wash cycle and check the water level inside. Try to add a few cups of water manually to see if the spray arm will spin.
Remove the toe panel and touch the motor while it's on wash cycle. You should feel it.
CarceKurihara
#8 Posted : Sunday, May 8, 2022 5:35:44 PM(UTC)
CarceKurihara
United States
Hey thanks for the super helpful reply. I'm not sure how I missed that thread. I haven't quite mastered the search function on here. I think I'll pass with him this time around. If i want any further guideline we will contact you here https://forum.appliancepartspros.com/posts/t515684-floridalottery-frigidaire
Edited by user Sunday, May 8, 2022 5:36:57 PM(UTC)  | Reason: Not specified
Guest (5)
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire fill tube leak: Is it just a bad design? (Refrigerator & Freezer Repair)
by bobhucker 6/18/2024 7:59:46 AM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Frigidaire FGHT2055VF - light switch? (Refrigerator & Freezer Repair)
by ranger58 6/13/2024 11:14:06 AM(UTC)
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Frigidaire French door temperature (Refrigerator & Freezer Repair)
by Guest 5/28/2024 4:10:07 AM(UTC)
Frigidaire PLHS238ZCB1 Refigerator compressor issues. (Refrigerator & Freezer Repair)
by TonyMertz 5/18/2024 9:32:13 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Frigidaire Gallery dripping through water dispenser (Refrigerator & Freezer Repair)
by cascodo 5/6/2024 9:26:01 PM(UTC)
Frigidaire FFHT1835VB1 Stuck in Defrost Mode (Refrigerator & Freezer Repair)
by dcuozzo 5/6/2024 9:55:29 AM(UTC)
Frigidaire Affinity front loader code (Washer Repair)
by Volusiacrazy 5/1/2024 3:26:17 AM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
Frigidaire fgus2642lf2 auger not getting power (Refrigerator & Freezer Repair)
by knmens 4/15/2024 6:17:43 PM(UTC)
