my washer goes though the cycles but wont spin. Belt is good and the motor starts to turn but just turns a little. I put in a full load and was stuck with wet clothes. I tried a small load too, no luck. Can anyone help? It is a front loader and I run only one load per week. It maybe 9yrs old but not over worked. It is not the motor I am sure. My last frigidaire lasted 18yrs and paid a lot less. What could it be???
Try replacing the motor/speed control unit, this part here. Part number: AP3967975
It is an expensive part, but if you buy from this site and the part does not fix the problem you can return it.
