jdeemer
#1 Posted : Wednesday, January 2, 2013 12:31:23 PM(UTC)
jdeemer
I'm having an issue with our Maytag MAV6357AWW washing fine, but not spinning fast enough to drain water. I checked the belt and it's extremely loose. Not sure how it gets tight due to the fact that I can just move the motor back and forth with ease. Is there a way to tighten the motor down to create more tension in the belt? It seems to slide back and forth effortlessly. :confused:
sidfink43
#2 Posted : Friday, January 4, 2013 3:08:16 PM(UTC)
sidfink43
The belt is loose because the motor motion serves as a clutch, so that is not the problem.
On these models if there is a spin problem the thrust bearing
Part number: AP4009132
is the first thing to change out. Directions are included.
jdeemer
#3 Posted : Friday, January 4, 2013 3:20:17 PM(UTC)
jdeemer
Thanks sidfink! I'll see what I can do. Do you know how difficult changing out that thrust bearing is?
