Humility
#1 Posted : Saturday, December 29, 2012 8:48:37 PM(UTC)
Humility
I have a Whirlpool LER8648PWO dryer that we have had for a few years now and it now will not start.
It has power, when I set the timer it starts spinning down. The heat element works fine (Bypassed the thermostat to manually turn it on and check). I picked up a new switch and tried replacing that, but it had no effect. The door switch is properly registering that the door is closed.
I do not have an ohm/multimeter on hand, but have most basic tools I just do not know dryers at all so I don't know what would be my next step to look at.
Thanks in advance for any insight you guys are able to offer!
#2 Posted : Tuesday, January 1, 2013 2:42:12 AM(UTC)
Parts for Whirlpool LER8648PW0 Dryer - AppliancePartsPros.com
See the attachment for your wiring diagram.
Most like likely part is the thermal fuse (item 7 in the Bulkhead Parts section).
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LER8648.pdf (250kb) downloaded 19 time(s).
Humility
#3 Posted : Tuesday, January 1, 2013 3:21:17 PM(UTC)
Humility
Bypassing the thermal fuse did the trick, I'm placing an order for one from this site now. Thanks a bunch for your help!
#4 Posted : Wednesday, January 2, 2013 1:41:29 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Jstarve
#5 Posted : Sunday, June 30, 2013 8:01:19 AM(UTC)
Jstarve
Thanks for the help this thread also fixed my dryer Thanks again.:)
Guest (4)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
Maytag Ensignia Gas Dryer will not start. (Dryer Repair)
by MRWHO 8/17/2012 6:00:48 PM(UTC)
Dryer will not start. Need help with 3 terminal start switch (Dryer Repair)
by EDogzz 5/17/2012 6:38:26 PM(UTC)
Whirlpool Duet dryer will not start. Sensing light on then a click. (Dryer Repair)
by dmariola 4/12/2012 6:47:43 AM(UTC)
Whirlpool dryer will not start. (Dryer Repair)
by c33341 3/11/2011 9:47:28 AM(UTC)
