Parts for Whirlpool LER8648PW0 Dryer - AppliancePartsPros.comSee the attachment for your wiring diagram.
Most like likely part is the thermal fuse (item 7 in the Bulkhead Parts section).
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
