10 Pages«<56789>»
katmandu81
#61 Posted : Sunday, December 30, 2012 11:19:55 AM(UTC)
katmandu81
What exactly is wrong with your refrigerator?
What is the complete model number of the refrigerator?
Have you done any troubleshooting? If you have, how did you do it?
Hi Gene. Model GD5PHAXMS10. Last year the icemaker stopped making ice. Troubleshooting so far; replaced water inlet valve based on chat with applicance staff. Water dispenses for water feature but does not fill icemaker. Swapped cables; water did not fill icemaker. Based on mapilla's post; verified optics work. I pulled icemake to test cable but 'operator error' (don't know what I'm doing becz nothing happend). Re-installed icemaker filled it with water; ice cubes froze but did not cycle cubes into container. I believe I have tried most troubleshooting; last thing is to figure out how to clean out icemaker line. Any thoughts on how proceed would be greatly appreciate. ty Kat
#62 Posted : Tuesday, January 1, 2013 2:54:53 PM(UTC)
Hi Kat,
Perform the diagnostics as described in the attached file and post the results.
Here are the breakdown diagrams and Parts for Whirlpool GD5PHAXMS10 Refrigerator - AppliancePartsPros.com
File Attachment(s):
In door ice system - component diagnostics.doc (167kb) downloaded 70 time(s).
katmandu81
#63 Posted : Wednesday, January 9, 2013 7:36:43 AM(UTC)
katmandu81
Gene, based on the directions you provided, nothing happened when I applied jumpers to T and H. However, when I inserted them to L and M, a small spark snapped in the M hole..maybe the end of the cable was wet?
Next I went to the LED codes. There are two constant pulses. Since the optic path was not blocked, should I conclude that I need to replace both boards?
What do you recommend I replace? ty again Kat
#64 Posted : Thursday, January 10, 2013 2:53:31 PM(UTC)
Hi Kat,
I'm afraid that you have to replace the optic boards as well as the ice maker.
- The optic boards kit Part number: 4389102
- The ice maker Part number: 2198597
katmandu81
#65 Posted : Friday, January 11, 2013 5:23:49 AM(UTC)
katmandu81
When my mom comes over she takes ice from my house to hers and drops it in the bucket :) I told her she can still can over. While it's not the answer I was looking for :( I appreciate your time and guidance sorting this out. Kat
Hi Kat,
#66 Posted : Friday, January 11, 2013 1:47:30 PM(UTC)
katmandu81
#67 Posted : Tuesday, January 29, 2013 7:57:51 AM(UTC)
katmandu81
Gene, thank you. My mom has more ice than she knows what to do with :) I appreciate your patience and help. Kat
#68 Posted : Tuesday, January 29, 2013 6:01:04 PM(UTC)
You are welcome Kat. I'm glad to hear your mom is happy.
Eshyu
#69 Posted : Thursday, March 14, 2013 9:45:20 AM(UTC)
Eshyu
Gene:
I have a KitchenAid Superba refregirator made in 2002. The problems is that no water going into the ice maker tray. I have replaced the the optics board, so the optics is working fine. In stead of switching the plugs from the valve that puts water to the door (it is a little tough for me to reach the valve), I manually put water into the ice maker tray. It makes ice, but the ice won't go to the ice basket. What can I do to further diagnose the source of the problem?
#70 Posted : Thursday, March 14, 2013 11:56:33 AM(UTC)
10 Pages«<56789>»
