Spanky84
#1 Posted : Monday, December 24, 2012 1:58:52 PM(UTC)
Spanky84
Frigidaire side by side freezer just doesn't get cold enough. I have cleaned the compressor and compressor coils. All fans are working. The defrost cycle works fine. The Evaporator doesn't ice up, it just gets frosty. The Fridge is exactly the correct temp. There is free airflow with no blockages. The evaporator fan is running almost continuously, except when the defrost cycle kicks in. The compressor pump shuts off, then comes back on occasionally. I am not sure if the thermostat is bad (I don't get appreciable changes on temps by adjusting the freezer or fridge thermostat controls). Maybe I am low on freon? Not really sure...kinda stumped? Any help? :confused:
Simon / APP Team
#2 Posted : Monday, December 24, 2012 3:28:08 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Check if the evaporator coils are covered with frost completely.
If they are try to adjust the temperature for coldest freezer.
Measure the freezer temperature.
If they are not covered all the way - then it's a sealed system problem and you need a professional repairman.
Post the results.
Simon.
Spanky84
#3 Posted : Tuesday, December 25, 2012 3:47:20 AM(UTC)
Spanky84
Simon,
Coils are evenly frosted. When I woke up, everything was cold (fridge was fine) and freezer was -7C...just like it had been. The fans and compressor were not running until I opened the doors to check the temps, then the system kicked on again. Still holding normal fridge temps and weak temps (-8 - -5 C) in the freezer. Must be global warming? Any Ideas?
#4 Posted : Tuesday, December 25, 2012 8:27:45 AM(UTC)
Remove the freezer panel and wet your finger and touch any exposed coils. The skin should stick to all the coils. If not, or just some places, you have system problems for a pro to look at.
It would help if you posted the fridg and freezer temeratures in farenheight.
Spanky84
#5 Posted : Tuesday, December 25, 2012 8:37:49 AM(UTC)
Spanky84
richappy,
Did what you said. All coils in the evap are evenly frosted and are the same temp. All passed the test as directed. Fridge temp hovers around 38-38F (5C) and the Freezer is 20-22F (-7--6C) not cold enough for Ice Cream....
Not having any luck... any additional Troubleshooting?
#6 Posted : Wednesday, December 26, 2012 12:30:19 AM(UTC)
The actual evaporatore core temperature should be around -20 degrees, yours is not. Suspect sealed system problems.
Kenmore (Amana) 596.79142993 Refrigerator & Freezer not getting cold enough (Refrigerator & Freezer Repair)
by Guest 8/23/2021 12:17:10 PM(UTC)
Freezer not getting cold enough to freeze water/ice cubes (Refrigerator & Freezer Repair)
by Steve_K_163 4/6/2021 4:11:28 PM(UTC)
Freezer Not Getting Cold Enough! (Refrigerator & Freezer Repair)
by kag716 10/4/2016 5:40:27 PM(UTC)
Freezer not getting cold enough, Fridge Fine, my use is atypical though (Refrigerator & Freezer Repair)
by jamisonia 7/14/2014 8:53:17 AM(UTC)
ge upright freezer not getting cold enough (Refrigerator & Freezer Repair)
by Wwb1969 11/26/2013 10:46:44 AM(UTC)
by IndyDGR 7/29/2011 8:29:18 PM(UTC)
by jerry.kegelman@nasa.gov 6/9/2011 10:37:52 AM(UTC)
Fridge/Freezer not getting cold enough (Refrigerator & Freezer Repair)
by R3GUL8OR 1/1/2011 6:45:32 PM(UTC)
GE Bottom Freezer Not Getting Cold Enough (Refrigerator & Freezer Repair)
by jackt402t 7/22/2010 3:51:42 PM(UTC)
by rswilson1844 9/23/2009 5:11:47 PM(UTC)
refrigerator/freezer not getting cold enough (Refrigerator & Freezer Repair)
by speedball 6/22/2009 9:29:09 AM(UTC)
by econner1 8/5/2008 6:36:33 PM(UTC)
by eaglebird 6/5/2008 10:58:52 AM(UTC)
