My Maytag Side By Side Mod. Mzd2667hes Does Cool Either Freezer Or Refrigerator Side. The Lights Come On On The Freezer Side But Not The Refrigerator Side. Neither Compressor Or Fan Is Running. Any Ideas How To Repair.
Most probably a bad Jaz board behind the control panel, or no power to it which is rare. Part # 12868513
Originally Posted by: richappy  Most probably a bad Jaz board behind the control panel, or no power to it which is rare. Part # 12868513 Actually there is power to it, but the control board onlys shows straight horizontal lines for the up down buttons that control each side.
Try unplugging the fridg for a period, might re-set the computer. If that works, add a 1000 joule surge protector to the wakk outlet, I use a Belkin one available on Amazon.
Side By Side Does not Cool Either Freezer Or Refrigerator Side. The Lights Come On On . The Compressor and Fan are Running. Any Ideas How To Repair.
:confused: Side By Side Does not Cool Either Freezer Or Refrigerator Side. The Lights Come On On . The Compressor and Fan are Running. Any Ideas How To Repair.
Originally Posted by: richappy  Most probably a bad Jaz board behind the control panel, or no power to it which is rare. Part # 12868513 Is this hard to replace and what is a jaz board?
Post the correct model # andmake
Originally Posted by: richappy  Post the correct model # andmake Maytag Side By Side Mod. Mzd2667
Originally Posted by: jbbellin  Maytag Side By Side Mod. Mzd2667 sorry about that here is the full number Mzd2667hes. also the compressor is not running
