dexann
#1 Posted : Monday, March 9, 2009 9:39:22 AM(UTC)
dexann
Both the freezer and refrigerator quit cooling. Fan motor at bottom rear of cabinet is running all the time. I can unplug the unit/or turn control to off for a couple of minutes and then turn it back on and it will run for a little while. It even makes a little ice. Any ideas? Thanks in advance for your help.
#2 Posted : Monday, March 9, 2009 10:51:07 AM(UTC)
Sounds like your compressor is seizing after a short run.Pull the off and check.
If so, a tech. can put in a supco oil additive (Supco 88) that will fix this.
Freezer/refrigerator Not Working (Refrigerator & Freezer Repair)
by jbbellin 11/22/2012 10:50:57 AM(UTC)
Freezer/refrigerator not working (Refrigerator & Freezer Repair)
by Kevykev 8/8/2007 6:22:33 PM(UTC)
